2021 XLT wiring - does Ford use standard wiring bundles in all the F150's?
jdr
IL
F150
Does anyone happen to know if Ford uses standard wiring bundles in all the F150's? Meaning, I want to change my tow mirrors on my XLT to the Lariat power fold. Would I just be able to change the mirrors because the proper connector is inside the door panel or would I need to obtain an adapter?
Jesse-Infotainment
2024 F150 Lightning Platinum
Same connector. But not all the wires are there
jdr
jdr
IL
F150
Thank you however, what is meant by not all wires are there?
I have seen a youtube where the installer needed to purchase an adapter, make modifications to enable everything to work. His XLT was not a 2021.
Jesse-Infotainment
I installed the lariat power fold on my truck. Connector is identical. What I mean by wires not being there is the wires for the power fold and dim if you have auto dim mirror. I added all of that. You will also need a new window switch and programming of a couple modules
jdr
jdr
IL
F150
Many thanks for the information. It sound very similar to the you tube I saw.
jdr
jdr
IL
F150
I have part numbers for the mirrors (ML3Z176....) and switch (FL3Z145....). Just wondering how they compare to what you have done. Thanks
