Android Auto Turn by Turn in Gauge Cluster - Incorrect distance
heffer86
Iowa
2021 F150 Lariat 501A
With my update to Sync version 21281 Rev244 I get the large turn-by-turn direction large in my gauge cluster using Android Auto. I always had the little arrow at the top. I was using it for the first time day an noticed that anything between .5-.1 shows as 0.0 in the cluster. When I get into the feet (ex 500ft) it shows correctly. Curious if anyone else has this. I'll try Apple CarPlay later to see if it does the same.
Ford F-150 Lightning Android Auto Turn by Turn in Gauge Cluster - Incorrect distance Screenshot 2022-01-28 135022
discothan
SW Michigan
2021 F150 XLT
Interesting variance.
So Google Maps through Android Auto?
I don't have a full digital instrument cluster, but I will test to see if I can get my AA nav view up on 'My View' portion.
rado
United States
2021 F150
Mine does the same. Once you get closer, the mileage drops to zero (no idea why), but the animation of when to turn gets shorter and shorter.
RedTXV
2021 SQ Limited
Mine does the same with CarPlay. Noticed it a few weeks ago.
Edit: I don’t think I’ve had an update, so it’s been going on for a while.
heffer86
heffer86
Iowa
Yep, Just used CarPlay. Same result. Doesn't really bother me, but just wanted make sure it wasn't just my truck.
Ford F-150 Lightning Android Auto Turn by Turn in Gauge Cluster - Incorrect distance PXL_20220128_224856079
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi there! Will you send us a message with your VIN and dealership info? I can look into things on my end. Thanks!
dhrandy
Randy
Concord, NC
1950 Plymouth, 2021 F-150 Lariat 500a
Engineering Tech
Mine does the same thing. Truck was built in October, haven't had any updates since it was built.
turbospartan
CO
2021 F-150 PowerBoost Lariat
I thought that was how it should work by default? Mine shows 0.0 as well, but the little blue bars on each side get smaller and smaller as you get closer to the turn.
RedTXV
2021 SQ Limited
Mine starts showing distance once it's at about 500'.
