daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
Sorry if this is old news but I think I understand the resulting behavior after enabling "cameras in motion" on a Job1 truck. I made the Forscan changes over a week ago but I assumed I still needed IPMA/APIM updates due to my flawed testing. I based mine "not working yet" assessment on 1) The bed camera card I added still didn't work and 2) The view I had up on the screen went away around 8mph
However, after @iceman77 was kind enough to check my VIN and tell me I have the latest IMPA and APIM both, and that the bed camera card does NOT work for a Job1 truck, I did more testing. Here is what I found:
When enabling using the hard camera button in motion, the first screen I get is always hitch view full screen (not sure why I would want this but whatever) and 2nd press of the hard button gets me bed camera (finally!) on left and 360 view (also cool) on right. This is really all I need, I can live without the bed camera card option. Additionally in motion, I cannot select using the soft buttons any other view except 1) full screen hitch or 2) split screen bed + 360.
When sitting still I can select any view, but having any view other than the above 2 options, camera disables at 8mph.
I'm going to assume this is same for all the rest of us Job1 sufferers, and thanks for the support in getting this (mostly) working!
Jesse-Infotainment
2024 F150 Lightning Platinum
That’s the way job one trucks work only job 2 and later get the cargo cam on side stack and full screen and other views at speed
Spindrive
Matthew
F150
So what settings did you use to get this working like this?
Twilly 3.0
Trevor
Alberta, Canada
2021 F150 3.0L Powerstroke, 2021 Edge SEL
What changes need to be made in order to enable the Auto temp on the seats?
I have a 502A Lariat.
daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
I directly applied the ones on the spreadsheet first page of iceman's pinned post at the beginning of this thread. For Job1 cameras in motion.
I know you need the IPMA updated from the one that came with the truck, and I was ready to ask the dealership but he also confirmed in FDRS that I have the latest IPMA and APIM (2 of the biggest modules). They must have come in OTA as my dealer has never touched these.
ROBB1
Justin
NC
2021 F150 Tremor
HVAC
733-01-08 xxxx x1xx xx (Original As-built 0)
APIM
7D0-02-02 1xxx xxxx xx (Original As-built 0)
sysop
Joe
2020 F150 Lariat 145 - 2022 F150 Lariat 157
worker bee
HVAC
APIM
What if your "Original As-built" was not 0? The AB on my HVAC was 4 and these settings do not work for me.
ROBB1
Justin
NC
2021 F150 Tremor
I should have copied my disclaimer from the original post as well for clarity:
My truck is a 2021 402A Tremor which is equivalent to a 502A Lariat. Other trims should verify your original as-build against the spread sheet for possible differences.
If you have “4” in HVAC 733-01-08 xxxx x*xx xx
Use 5
Platinum Peasant
West Sacramento
Can anyone recommend a sub $200 laptop to use for forscan? I’m a MacBook user so I’m trying to make sure I get the right one.
ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
What are the job two version?
My Sync (SYNC4 v4.0.21136)
Will this works with mine?
Eco_Beast
Kevin
Maple Ridge, BC Canada
2022 F150 3.5L EcoBoost
Electrician / Graphic Designer
Hey guys I'm trying to add Rock crawl but I don't see an ABS module anywhere? I've been able to successfully complete a few other things, just can't find the ABS 760 module.
sysop
Joe
worker bee
At that price-point there is a high chance of issues.
itsdchz
Lee
Clovis CA
2021 F150 Powerboost FX4 XLT with Stuff
From the speedo thread. Any info/thoughts would be helpful:
Help??
I have gone from 265/60/20 stock Hankook to 275/60/20 more aggressive Cooper Discoverer ATS. When pulling up my info in a 2021 Powerboost, under BdyCM, I look at the appropriate fields but they do not match:
Stated info from OP: 726-15-01 xxxx xxxx ABxx - This field already contains the correct value in my vehicle: xxxx xxxx 09xx (based on code gen, both sizes have this same value present)
Stated info from OP: 726-15-02 CDxx xxx xxxx - This field only has the parameters in 2 segments, ie: F3xx xxxx
Based on my stock configuration, I should have 726-15-01 as: xxxx xxxx 09xx - this is the same for new parameters as that value did not change - OK
What would I change for 726-15-02? My stock parameters are: F3XX xxxx (no 3rd segment) (the stock parameters in the HEX generator suggests that based on 265/60/20, I should be CD- CDxx xxxx xxxx, even though F3 is present on as built parameter)
The Hex generator states I should have F2 as the new value, however when I replace the F3 to the new F2 value, it states that my checksum is wrong, so I did not write The code and perform the DTC check.
Any ideas if the Powerboost BdyCM and 726-15-02 is different on 2021+ and should only contain 2 segments, not 3, and if I write the F2 value vs F3, if this is truly for the tire size?
Thanks in advance.
In summary:
As built on 2021 PowerBoost - came with 265/60/20 Hankooks- Added 275/60/20 Cooper
I have stock configuration:
726-15-01: xxxx xxxx 09xx
726-15-02: F3xx xxxx
Hex builder states I should have stock configuration as:
726-15-02: CDxx xxxx xxxx
Hex builder with new tires:
726-15-02: F2xx xxxx
Forscan v2.3.46
