Exact heights
Dave242
IL
2015 F150 XLT, 2023 F150L
I have a very low garage door opening - 77.5". The prelim specs list the Lightning height at 78.9".....and I can find no production specs anywhere. Does anyone know for certain if that 78.9" is for the Platinum (22" wheels)? Is it safe to assume that the Pro (which is what I plan to get) that comes with 18" wheels will be 2" lower?
One other possible height adder is the rooftop antennas. The Pro does not have satellite radio so an antenna is not needed for that. Will the Pro have those antennas on the roof (GPS maybe?)? I can't tell exactly, but the antennas seem to add about 1/2" to the height.
beatle
Springfield, VA
I would check the tire size that the Pro comes with to ensure they are 2" smaller diameter than the Platinum. Wheel size sometimes correlates to smaller tires, but it technically it has nothing to do with the overall diameter.
rdr854
Northern Virginia
The clearance for my garage at work is 79.0 inches. Not much of a fudge factor.
Ruination
2012 F150 EcoBoost
Chemist
That's not how wheels and tires work. The wheel is just the rim. A smaller rim will have more rubber and visa versa. The height should be the same. Its not going in.
VTbuckeye
Vermont
18s are 32, 20s are 33, 22s are 32.8. Good luck. I hope it fits, but I would not count on it. The best dropping to 18s does is save 0.5 inches height. If you let most of the air out of the tires you could fit.
LightningShow
MA
'22 Lariat ER
Product Development
Perfect application for remote tire inflation/deflation!
My garage isn't really a garage, it's an old barn. The side facing the driveway has a low entry, I seriously doubt the Lightning is ever getting in there.
Time for hydraulic suspension mod!
Ford F-150 Lightning Exact heights A12BB4EB-030B-4068-B879-2F3028ADB0A6
Dave242
IL
hahaha...I think those low profile tires would do the trick by themselves. Great suggestion!
LightningShow
MA
'22 Lariat ER
Product Development
Oooh, I just measured my barn entrance, it's actually 78-3/4"...so tell me more about this hydraulic suspension! ?
frautumn
Fred
Northern CA
2022 Ford F-150 Lightning Lariat
The "2022 F-150 Lightning eSourceBook.pdf" (which somebody posted here a few months ago in another thread) shows the height as 78.3" (Code N in the diagram below). The footer for the document lists the date as Jan 26, along with the URL which is for dealers only so won't work for us customers: "https://www.esourcebook.dealerconne...e/F-150-Lightning/2022.printable.vehicle.html
1/26/22, 7:58 PM"
Assuming it's correct, it is still too high for your garage, but it's 0.6" lower than the figure you posted. Not sure which is right, anybody have a source for the 78.9" figure?
Ford F-150 Lightning Exact heights lightning esource
Dave242
IL
Thanks for the info! It is indeed slightly different (on several dimensions) from what I got from https://fordauthority.com/2021/06/here-are-all-the-2022-ford-f-150-lightning-specs/
Your source sounds quite authoritative (and much more recent), but I figured with the name of my source, they must be an authority! ;)
1/26/22, 7:58 PM"
SteffanG
Steffan
Langley, BC
2011 Audi Q5 (written off), 2008 F150 XLT HDPP
Just add 1000lbs to the truck and it should be low enough to get through ?
Ruination
2012 F150 EcoBoost
Chemist
If the tires are an inch smaller that would be 6 inches lower.
