Adding a Sub to non-unleashed BO system
Tldx07
TYLER
Long Island
2021 F150
Here are a couple of photos. I haven't bolted the kicker down yet, time was tight. One piece of advice, the kicker positive lead was not long enough to go from behind the SCrew rear seat, down the door jam, through the firewall (used hood releasd grommet) and to the battery, had to add a little more wire.
Thank you for the pictures appreciate it. Going to give it a shot this weekend maybe, considering tapping into the existing wiring after the B&O amp, may try and leave the factory sub hooked up also. Some people say its possible as long as your after the amp running a self powered sub, anyone know if i would need anything in addition? such as a LC7i or Keyloc? i saw some poeple mention them in other threads.
dm5point0
Atlanta, GA
2021 F-150 Lariat FX4
UPS
I am planning on doing this as well, but I have done some research and to get the most out of the sub, you would need an LCi2 or LCi2 Pro (I have a pro on the way). Otherwise the signal will start to drop off as the music gets louder because the factory wants to keep from blowing the crappy stock speaker.
BCrippsy38
New Hampshire
2021 F-150 Lariat Powerboost
Would tapping into the rear door speakers be a better approach than the factory sub?
dm5point0
Atlanta, GA
UPS
Not from what I have seen. The factory DSP is tuned to eliminate clipping and the door speakers would probably clip faster than the little sub.
BCrippsy38
New Hampshire
Ok good to know. Heard clipping could be an issue, was hoping the dsp used feedback from the speakers where disconnecting the factory sub would remove that concern.
dm5point0
Atlanta, GA
UPS
I am just using the LCi2 Pro to make sure :) AND I am removing the factory sub.
Graygoose2021
Central US!
2021 F150
Sales
The KEYLOC would work perfectly, flatten the factory EQ' and allow you to boost it with the HS10.
Tldx07
TYLER
Long Island
2021 F150
I pulled these from another thread on F150fourm kudos to a 'Oscare' who posted them. This is using a separate amp and sub but again i'd wire it to the kicker hideaway.
This is tapped after the amp just before the stock sub connector. From what I can see he tapped both positives from the LC to the Positive on the stock sub, Both negatives on LC to negative on stock sub.
The rest is a little tough to see, Im no audio guru so these are my uneducated assumptions;
- LC2 remote out ties into the kicker remote on.
- LC2 remote in? would you need to tie in the stock amp remote to this?
- Positive feed, can i pull off the stock amp or better off dedicated/fuse box?
- Negative you guys mentioned threes a few screws for grounding.
LC2 Bass output RCAs to the Kicker hideaway (I was going to add the Kicker KISL RCAs from the hideaway harness so I can just plug them together)
Ford F-150 Lightning Adding a Sub to non-unleashed BO system 27992e71_dbd5_4461_9b5d_f640b6f60b37_dca214e957e1a7ed9bcd9e354e93481a8aaa9de4 (1)
Ford F-150 Lightning Adding a Sub to non-unleashed BO system 2ab2e2218_4605_46af_a6be_9b7c67e912eb_9d1f0d794cc89816bd9ea51f720d64722e26d2b2
ISLANDF150
Kyle
Ontario, Canada
2022 Ford F150 XLT FX4 3.5L Ecoboost
27992e71_dbd5_4461_9b5d_f640b6f60b37_dca214e957e1a7ed9bcd9e354e93481a8aaa9de4 (1).jpeg
"This is tapped after the amp just before the stock sub connector. From what I can see he tapped both positives from the LC to the Positive on the stock sub, Both negatives on LC to negative on stock sub."
This is what I did for mine except I didn't need the LC2i bc my amp has that feature...postive on stock sub is green and grey is negative...Confirmed it works.... Ran a power cable to the battery. Ground to a bolt on the back wall...and the bass is back!
magg992001
Clint
Stony Plain, AB
2021 F150 XLT 3.5EB
[/QUOTE]
Where did you get remote power from to turn on the AMP?
93dpscoupe
Bruceville, Tx
01 GMC 1500, 93 Mustang LX, 12 Mustang GT
Product Development @ LMR.com
TJSparky
WA
2021 F150 XLT (302A) RockyRidge K2
Thanks all. It definitely sounds better than the baby sub they put in.
