- First Name
- William
- Jan 8, 2022
- rural Georgia
- 22 LIGHTNING PRO IcedBlueSilver 8/23/2022
- Occupation
- Owner
2022 Ford F150 LIGHTNING San Antonio Drive event:
*****Iced Blue Silver Metallic : ) yes, I'm now VERY happy I have stayed with that choice!
FORD provided some terrific opportunities for a few of us OWNERS, with upcoming deliveries, to DRIVE, RIDE, and CHECKOUT the many LIGHTNINGS available at the event...thank you Ford! Here's some quick observations and questions I found answers to:
- if you find yourself pressing the OFF button without remembering to put the truck in 'park', it will do it for you : ) The gear shifter will MOVE, on it's own, back into 'park'.
- the 'STOWABLE Gear Shifter' feature also works smoothly, when parked, but, unfortunately for those trims with the folding 'computer desk', the gear shifter will NOT stow while driving. I can see why Ford may not allow it to, but maybe in Lightning 2.0 models, they will allow for this to happen since the gear shifter is really no longer a 'mechanical' link to any transmission, but just a different 'device' to do the same action as the rotator knob, as on many other EVs, or even the right 'stalk' on a Tesla.
- 'One Pedal Driving' is available in several drive modes. The feature can be either engaged in those modes, or disengaged, if you prefer to drive without it. This feature provides maximum regeneration, but also provides AUTOMATIC application of the brakes, when/if needed, to bring the vehicle to a complete STOP. This also automatically engages the 'HOLD' feature, allowing you to let your foot completely off the pedal, while still remaining stopped. You simply press the pedal when you are ready to go again. This is absolutely terrific when in stop and go traffic - you will LOVE it.
- 'Tow/Haul' mode provides the technology to aid in backing, trailer connecting, trailer sizing and weight scale measurements, etc., but does not otherwise change the 'driving' of the vehicle, since there is no 'transmission' to downshift, etc. Also, while Tow/Haul mode is engaged, and the 'one pedal driving' may not be available, the Lightning CONTINUES to regenerate when you lift off the pedal, even though you certainly may not 'feel' the same effect - also, the weight of any towed item is going to already aid in more regeneration than the truck itself would have, on it's own. 'Losing' regeneration is NOT a factor, it's just a different feel than when one pedal driving is engaged, which also engages the BRAKES, when it needs to. Tow/Haul mode, without one pedal driving, makes the DRIVER apply the brakes.
- TOWING: If you have the additional option of the 'Max Towing' package, you will also get the additional Battery COOLING, which is active regardless of whether you are towing, or not.
- the 'Active Air Dam', which is now already on most all 'regular' F150s, is a feature built into ALL Lightning trim levels - it is an additional 'valance' that deploys downward about 4-6 inches, just behind the front bumper valance, when at speeds of 45mph or higher, to aid in aero for even better range. It automatically 'stows' back behind the front valance when you are then LESS than 45 mph. Unless you are traveling next to an F150 with this feature, you will actually never 'see' it in action, but you can certainly see the Air Dam mechanical device mounted behind the front bumper/valance.
Feel free to ask any follow-up questions, or your own comments, if you feel they are different. My experience with my own EVs in my garage provided some easy 'comparisons' to this great LIGHTNING truck - one pedal driving, 'auto park', etc.
I can also tell you that my 'impressions' of sitting in the driver seat of the LIGHTNING, getting a 'feel' of the environment, the technology, the screens, and the low-speed driving test, this new truck is SO IMPRESSIVE. The Tesla model 3 long-range that I drove 2,400 miles to San Antonio and back is NOT as impressive.
The LIGHTNING is obviously putting you up into a much HIGHER seating position, which provided me more of a 'commanding' feel, but the quite and easy movement of the truck also tells me that DRIVING It long-range will be very comfortable.
Having a very USABLE and spacious front-truck, along with the electrified BED, and the towing capability, makes this THE vehicle, whether for an every-day casual driver, or the contractor going from site-to-site.
I'll also add that the rear seating area is absolutely the largest I've ever experienced. There is a FLAT floor, and even impressive storage under the seats when they are being used, but if you REALLY need a cavernous 'inside' storage area, just FLIP the rear seats up, and 'voila(!), you have another MASSIVE area for multiple uses - dog crates, luggage, golf clubs, a mini-frige, large COOLERS, camping equipment, CASES of beverages(!), or anything else you can think of.
Thank you FORD : )
William - west central GEORGIA
Iced Blue Silver Metallic 2022 Ford F150 LIGHTNING PRO
- max towing package
- towing technology package
- 9.6kw ProPower Onboard package
BUILD Schedule: MAY 2022
Thank you FORD : )
