Wheel offset measurements
Bviza33
Brad
Upland CA
GT500, Mach e
Business owner
I have a set of wheels ordered for my new platinum Lightning that will hopefully be here in the next few weeks. Has anyone received theirs yet? I really need to get some measurements so I can them to the manufacturer. I'm not a fan of the stock wheels.
Ford F-150 Lightning Wheel offset measurements Screenshot_20220529-094809_Chrom
SteffanG
Steffan
Langley, BC
2011 Audi Q5 (written off), 2008 F150 XLT HDPP
Be careful with aftermarket wheels. For one, you will reduce range by a fair amount with a style like that, and second the lightning weights more than an ICE truck so the rims need to be rated a lot higher (the truck is probably close to 2000lbs heavier) and would affect the GVWR of the Lightning.
VTbuckeye
Vermont
ER has gawr front 4050, rear 4800, SR is 3750 front, 4900 rear. At least 1/2 gawr is appropriate for wheel load ratings. Aftermarket wheels with load capacity of at least 2450 pounds should be ok. I believe that standard offset is 44mm. Someone please correct me if I am wrong.
T i h o r
Rohit
Toronto
Self Employed
Just wanted to bump this to see if anyone knew what the oem dimensions and offsets were for the various sets of rims.
data003
Maine
2022 F-150 Lightning Lariat ER (Totaled), 2025 F-150 Lightning Flash ER
Same, anyone have this info?
Bviza33
Brad
Upland CA
GT500, Mach e
Business owner
I will hopefully get my F150 Lightning Platinum next week sometime. I'm going straight to my wheel manufacturer for final measurements. I will post once I have them.
