Anti-theft measures
oddlou
Lou
Los Angeles, CA
2021 F-150 Star White Platinum 4x4 Powerboost
Hi, all. I was looking at the mostly annoying Neighbors app on my phone (lots of "I saw a coyote! (the animal, not the people-trafficker) and "I heard a loud bang! Gunshots!?" (usually fireworks) and "there's a helicopter flying around, anyone know why?!" (because you live in a city)) and noticed a few instances of actually concerning crime--there's been a lot of catalytic converter and tailgate theft. I usually park my truck in my driveway inside my gate and making sure the tailgate is locked helps, but was curious to know if any of you have installed any anti-theft measures for your tailgates and/or catalytic converters.
Thanks,
Lou
discothan
SW Michigan
2021 F150 XLT
Install flood light(s) that have motion detection/turn on by motion.
Also if there is a Window view from your house down to your truck, might install a web cam that has an app or SimpliSafe monitoring.
Plat_2021
Dennis
MN
2019 F150 Lariat Sport, 2021 Platinum (on order)
Network and Security Consultant
the Platinum has a standard alarm system with motion detection, that I think would go off if, especially for the tailgate. if you can climb under the truck and cut the catalyst converter off without disturbing the motion sensor you might be able to get a way with it.
Bigal323
Canada, ontario
2021 F150
I wonder if it would possible to add a simple switch to the fuel pump relay without causing codes. Essentially you can put a switch or button anywhere. If the truck gets no fuel. It wont drive off. I dont know about cutting into a 2021 harness yet though....
BLoflin
Brooks
Austin, TX
2022 KR PB 6.5'
They aren't driving them off, they are cutting off the converters. On just about any car. And they are fast, battery powered side wheel cutter. There are business's fabbing a metal surround to slow them down and make them decide to move to the next car. But muffler and brake shops don't like them, when they have to work on the undercarriage, as they have to cut them off.
flatag
2021 Ford F-150 XLT FX4
I park under floodlights with 4 video cameras and one large scary German shepherd
UNIKRN150
Bob
Pacific North West
Pinto SE 4x4
Just pull the relay and take with you. That's what I used to do with my Mustang.
jeffcrum
Slidell, LA
2021 F-150 XLT 302A Powerboost 7.2kw Inverter
Computer programmer
Use home protection. Not truck protection!
oddlou
oddlou
Lou
Los Angeles, CA
You guys revived this thread and then changed what it was all about! :ROFLMAO::ROFLMAO: That said, I'm not terribly worried about someone stealing the whole truck while it's on my property--it's parked behind my gate at night and @flatag, I'll see your "large" scary German Shephard and raise you a huge, ornery Neapolitan Mastiff and even bigger English Mastiff. ? My initial concerns were more about someone taking the catalytic converter or tailgate off the truck when it's not on my property. With the tailgate locking with the truck, I just have to keep reminding my wife to lock the damn truck. As for the catalytic converter, it still worries me, especially since it's so easy to get under these big ol' trucks, but it seems I just need to be smart about where I leave it.
Pedaldude
Arizona
A bunch of cats have been reported stolen on Nextdoor in my neighborhood as well. So I decided to look into it.
Most are using cordless Sawzalls but some are using grinders with cut-off wheels and still others, pipe cutters.
There's several concepts, one is to cage the so it takes longer, others wrap them in cable or clamps with cable or chain. The latter methods are taking advantage of the hope that the thief won't be carrying a bolt cutter to cut the chain or cable off, since there's a big challenge in cutting a moving chain or cable and if something like a wire ribbon is used, it can even foul the blade and jam it.
With a grinder, the best bet is to limit access and make it so the cat can't be removed without destroying it, or use aluminum which can load up most cut-off wheels and make them unable to cut.
There are also aftermarket transmission skid plates that cover where the catalytic converters are. I think one of those at the least will put you ahead of your neighbors, since it's really just about inconveniencing the thieves at this point.
Here are some pictures that I found looking around:
Ford F-150 Lightning Anti-theft measures A0B79820-D719-4931-A72A-DF37A547403C
Ford F-150 Lightning Anti-theft measures 766AD6C5-949E-4BB7-A218-EA9020A5DA21
Ford F-150 Lightning Anti-theft measures 7E8BD58E-F843-4B2B-93A4-8B04DCE2C636
Ford F-150 Lightning Anti-theft measures 85E1FAF6-BDBA-4B2A-80CA-478620336A52
Ford F-150 Lightning Anti-theft measures C6BD0158-EF3A-4885-BC9E-874D01D19A0C
Ford F-150 Lightning Anti-theft measures 2D4D261A-56FF-4B6B-924B-4C3A7CFC6309
Ford F-150 Lightning Anti-theft measures 0335CF02-DD3B-45CD-8ACD-782BC007F055
Ford F-150 Lightning Anti-theft measures 34A17082-B64B-4F17-A977-33B85A3DB9CB
Ford F-150 Lightning Anti-theft measures 739B8A42-15C6-4744-9EB3-97598F5C4173
Ford F-150 Lightning Anti-theft measures 8393A924-C94D-49A9-9F23-D61A7B7CF059
Ford F-150 Lightning Anti-theft measures EBA9AEED-85AB-4B90-AD89-E5699322253A
Ford F-150 Lightning Anti-theft measures 06E2E474-C98B-47FA-BF6B-D1E1FFD2A7D1
CarolynStride
Carolyn
SD
2021 F150 xlt 4x2
Retired?
Some of those are looking kind of Mad Max, lol. Subtract 40 lbs from available payload.
jperry5835
2021 F-150 Hybrid Platinum
some of those make me wonder about heat dissipation, those cats get really hot and need to shed the heat off.
Yellow Buddy
Smart Ass
are you guys talking about the ford lightning? because the lightning does not have a catalytic convertor.
Coming up on 2 years..how many pages back did you go?!
The post was from before the lightning forum split off to be its own. I'm going to guess that it was just carried over mistakenly.
Otherwise a good antitheft device for the Lightning would be to grab a standard 12v battery charger, turn it up to max, plug it into the Pro Power and electrify the shell of the vehicle. That would work right?
