Added OEM lighted running board to PRO via factory pigtail forward of the rear wheels and need to activate light in Forscan
jimfigler
Orchard park, NY
I used some extra silicone, this stuff, a couple drops on each end and in the middle. Didn't trust just the adhesive.
Loctite 908570 2.7 oz Tub Clear Silicone Waterproof Sealant, Single Tube https://a.co/d/iDFHx0Z
That is the same stuff I ordered.
abel408
Schenectady, NY
2023 F-150 Lightning Pro
Has anyone figured out how to activate the connector on trucks that do not have the tow technology package? I have the connector, but there is no 12v going through it.
Nftypjs
Dylan
Hawaii
f-150 lightning pro
Also, for those that have done this, can you show a pic or two of the location of the pigtails where we can access the lighting?
turbobeast
Parkland FL
2022 Ford Lightning Pro
Has anyone figured this out yet for a '22 Lightning Pro without the Tow Package? Trying to install the F150Leds.com Running Board LED kit, but we can't seem to find the correct wire to tap into. I tried using the pigtail and hooking them up on the existing plug under the truck, but that seems inactive. So far in the harness in the kick panel we have tried the Grey with Violet stripe and Brown With Green stripe. When using either one of those wires the LED's just flash with the unlocking and locking of the doors. They are on for less than a second. Thanks for any input.
Rollin
Antonio
2024 F-150 Lightning Lariat
I have a 2024 Lariat and can not locate the connector underneath the truck
hstrip
Heath
2023 Pro
Commercial AV
Hey guys. I ordered the Nilight kit. I have a Pro but I have the factory pigtail. I can't get the lights to work. After researching, my lights work but I found the plugs (both driver and passenger sides) only get about 10.5V. The lights won't work on 10.5V. I was attempting to find a dome light wire in the driver's kick panel. Along with the turn signal wires but I haven't been able to. Has anyone had any luck with a dome light wire and the turn signal wires?
Here is what I bought: https://www.amazon.com/dp/B0BSF4N2GH?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Jesse-Infotainment
2024 F150 Lightning Platinum
Here is the diagram
Ford F-150 Lightning Added OEM lighted running board to PRO via factory pigtail forward of the rear wheels and need to activate light in Forscan 1752702522410-br
Jesse-Infotainment
Thanks! Is the violet and green in the driver kick panel?
You would have to check. The issue will be these from factory are driven by the Door modules.
The puddle light circuit. SO not sure if Ford would prewire that or not. The lighted Steps seem to be a fairly rare option. C316 ia actually under the hood.. or I should say in the frunk area.
511 and 611 are the door connectors.
