Tailgate lock that fits the 2021s?
Pedaldude
Arizona
My XLT has a locking tailgate and I imagine that most do nowadays. However, the latch is completely exposed from inside the bed and it is only a matter of time before someone figures out how to jimmy it open and posts it on YouTube.
Ford F-150 Lightning Tailgate lock that fits the 2021s? E55B9D7C-3C25-447D-A58C-ECC036D0A69C
Ford F-150 Lightning Tailgate lock that fits the 2021s? A6874BC8-5E6E-4BBB-BAE3-43DD34FFF275
I looked into getting another tailgate to debadge and fill the embossed F-150 figures and even without the hardware or camera and light, it’s super expensive.
I might look into putting in a lock or hose clamp even though I like to remove the tailgate to sweep up the bed. Or maybe even fabricate an alloy plate to cover the exposed latch.
zdjelar
zdjelar
Saša
Houston
2021 F150 Limited (AMB)
Energy
The Ford Accessory website says the right part for 2021s is VFL3Z-18168-B. Has anyone tried it and had a problem with fit?
Update: I took a closer look at the tailgate (see the photo below). It looks like the part above will not fit. But I think the best solution is to replace the holding screw with a tamper proof one, which you can get at McMaster. I'm pretty sure the screw is a 6mm x 1, 12mm.
That’s precisely what I said. Good to see someone else to same conclusion.
zdjelar
zdjelar
Saša
Houston
Energy
How confident are you about the screw size? If so, that’s an easy purchase.
Lippy
CA
2021 F-150 Powerboost
Lippy
CA
The 6mm x 1mm x 12mm worked perfectly. The Ford bolt has an integrated washer that is attached to the bolt, so I had to find another. I also used a drop of Loctite blue and some SuperLube and I’m good to go. I put an extra tamper proof Torq key in the truck. I think this would be pretty hard to get off without that key, not sure how you could do it without ruining the bolt.
Ford F-150 Lightning Tailgate lock that fits the 2021s? 95E2CDF3-65F6-42CE-9E25-8CBFAC634001
JohngaltinOC
Scott
Orange County ca
2021 F150 lariat EB
Finance
Where do I find the torq key? all I have is a ratchet set with those
Hello, I have a ratchet set with that, but is there a wrench or other "key" out there that I can throw in the glove box?
Lippy
CA
You need a special tool for tamper resistant Torq bolts. You can get the tool at McMaster, only $3 or so. Basically like a hex key with a special end.
JohngaltinOC
Scott
Orange County ca
2021 F150 lariat EB
Finance
Ty, I took your lead and ordered the bolts, but looking around their site I didn't see a simple cheap tool like you describe. I was at work so might have missed it in my haste...I'll go back in there.
Lippy
CA
There is a link to the tool in the description of the bolts on the page where you order the bolts. Or you can search for Tamper-resistant torq and it'll pop up. The part number for the T27 L-key used on that bolt is 55525A29.
JohngaltinOC
Scott
Orange County ca
2021 F150 lariat EB
Finance
Thank you Lippy, meant to circle back yesterday. Really appreciate your help. I ordered 2. Very kind of you to make it basically idiot proof for me! Lol
Bryan Simon
Bryan
San Antonio, Texas
65 Ranchero, 66 ElCamino, 05 Ranger, and more
Maintenance
Anyone come across a tailgate lock that fits the 2021s? I ordered the typical McGard one but the plastic piece (for Ford’s) doesn’t fit. Did the tailgate change? Also seem to have a bolt currently holding it in place and appears if that was just a unique pattern bold (aka wheel locks) it would serve the same purpose.
Anyone put one on you’re happy with?
This was on the truck when I got it.
I vaguely recall discussing this when trying to order a 2020.
I guess the sales guy went ahead and put one on my 2021, but I was not charged for it at all.
It is a McGard lock with a Ford part number
Ford F-150 Lightning Tailgate lock that fits the 2021s? F8EA44C6-36E8-4140-9494-59AC658ABDAD
Trashman
Tracy
Cushing Oklahoma
Limited Powerboost
Didn't know where else to post this. Observations on locking tailgate from a person coming from an 2011 f150 with a keyed lock on the tailgate. Now when truck is locked, tailgate is also and with cover locked seems pretty secure. It won't unlock unless key fob in pocket but can open tailgate with truck still locked and key fob close. For me works exactly how I would want it to. For past truck owners this may have always been that way the last few years but loving the details.
Bryan Simon
Bryan
San Antonio, Texas
Maintenance
nothing is secure
I can see someone ripping the tailgate bezel right off for linkage access. Been being done for years.
Once that is off and the gate dropped, no big deal to remove a bolt and abscond with the gate.
Even the little hinge lock can be breached with some effort, and noise.
This lock comes with one of those keys with a weird design on the end, and a key number to match the flower shape of the key.
Otho got is foolproof, but every little bit will slow the crooks
oddlou
Lou
Los Angeles, CA
2021 F-150 Star White Platinum 4x4 Powerboost
nothing is secure
This one: https://accessories.ford.com/kit-lock-cylinder-repair-11334.html ? The part number matches up, but it looks a little different in your picture and the one in the link. It's hard to tell because of the different angles in the pictures.
nate2631
Nathan
Orange County, CA
2022 Ford Tremor
Do you have the power open and close tailgate?
