Trailer brake control
62F1004x4
Norman, OK
1962 F100 2023 F150 Lightning SR
Maintenance
PrimeRisk
Denver-Metro
Technonerd
A lawyer, $2500 in fees, a judge, and wait two years, you might be able to force Ford to pay to have it installed, but they would just send you back to the same dealers.
I'm not trying to get Ford to pay for the install, but paying something reasonable for a <1 hour service.
Sobmartin
Washington state
2016 F150 2021 Mach-e er
Ok, so I give up with my local dealers for getting an OEM controller installed. The dealership where I purchased it demands that my '24 Lariat has it, but clearly it does not and after 3 separate engagements, will not respond to give me a quote. The next closest dealer, where I first drove a Lightning but did not drive, says they do not service EVs. (WTAF, they literally will not service the vehicles they sell?) The 3rd dealer wants $700 to install it. $250 for the part and $450 in labor.
Ok, so I'm capable of physically installing it, but then I'd need to enable it in the software. Well, according to the Forscan.org website, they do not support any Model Year 24s.
Grrrr... Are there any other options or do I need to feed the beast $700 for something that should have been there in the first place?
I paid $600 for the install. Took 1.5 hours for hardware install and programming
PrimeRisk
Denver-Metro
Technonerd
Ok, this just keeps getting worse and worse. I spend 90 minutes on the line with Ford Customer Service and they are saying that since I didn't get the Max Tow Package, the brake controller literally cannot be added to my F-150 Lariat as the vehicle has already been built, there is no compatible part for the 2024, and if I attempt to install the part ML3Z19H332AB they will not support enabling it in the software and I jeopardize my warranty.
FML, I have a truck I cannot use for one of its key purposes.
PrimeRisk
Denver-Metro
Technonerd
What vehicle did you install it in? Was it a 2024 Lightning?
Sobmartin
Washington state
My dealer’s EV tech said,it wasn’t a problem either with the hardware or the software
PrimeRisk
Denver-Metro
Technonerd
Would you be willing to provide who your dealer is? Neither Ford Customer Support or Ford Parts believe there is a compatible part and maybe that tech can educate the company that actually designed and manufactured the vehicle.
Sobmartin
Washington state
Pat Armstrong Ford East Wenatchee WA
user-name-required
T
BC
2024 F150 Lightning Flash, 2023 ID4 pro S
Came here searching out for the integrated brake controller on my 2024 flash, as I also couldn't seem to figure out where to control it from, and I think I am in the same boat here with the coin slot instead.
That said, I wanted to share a good option we used to tow with our other EV, which is a BlueTooth brake controller from Curt Manufacturing. Link to a Canadian site at bottom
It costs just under $300 Canadian, you can take it with you to other vehicles, and in our experience over the last two years towing with our crossover EV, it has worked great.
I didn't expect to have to use it for the Lightning, but after reading this thread, it appears that I will have to. Towing my 19BH travel trailer now, I can tell it is activating the trailer brakes, but it is probably set to a default mid-high brake level. For Regen purposes, I want to dial that back so that more of the braking energy is coming from the regen system and not the trailer brakes.
Link: https://www.hitchweb.com/51180/echo...kZ0sn0XupxRCR8ZE1IEW0pSqO_cr8PjwaAp5TEALw_wcB
