TPMS sensors part number for 2024 Lightning?
WildBlue
Somewhere
2024 F150 Lightning Flash
Just purchased a set of 18" wheels and want to add a set of compatible or OEM TPMS sensors to them (I don't want to move the ones from my factory wheels over). I called my dealership and even with my VIN, they were able to narrow it down to three different Ford part numbers: TPMS-69, TPMS-117 and TPMS-116. He wasn't quite sure which one it was for my truck, though TPMS-116 appeared to be for vehicles equipped with trailer vision systems. In any case, does anyone have a correct part number they can offer? Or possibly compatible alternatives? I am not even sure which frequency (415 or 315mhz) our truck uses.
Thanks in advance for any help!
Check these previous posts. One mentions TPMS-68. Most are using third party sensors fine.
https://www.f150lightningforum.com/forum/threads/lightning-tpms-sensors-what-where-to-buy.12249/
https://www.f150lightningforum.com/forum/threads/advice-on-replacement-tpms-sensors.15248/
https://www.f150lightningforum.com/...ires-means-extra-tire-pressure-sensors.19176/
All these appear in the Similar Threads box at the bottom of your post (at least on a PC).
Deleted member 19053
Guest
Keep in mind that your year uses 433mhz. Any compatible 433mhz is fine. Ford, Autel, Harrington. If you have a tire dealer do this then just have them use their sensors. They stand behind them and they also have their tools for them.
San Diego
23 Lightning Pro
I had the sam
I had a similar issue. My Pro was 315mhz and the Flash was 415mhz. No idea why they switched. You might consider Autel Maxi tpms, that's what I used. Capable of being programmed to either frequency. I have the capability to program them for myself, but many tire shops can do so. Fraction of the cost, available online and at Napa etc.
