CHMSL Center Brake Light Wire for Cap Topper & Fob wires location
amesghali
ali
Gold Beach, Oregon
I just got a new LEER topper for my Lightning, but the installer was not able to connect the CHMSL or the FOB functions. Does anyone know exactly where these wires are located?
amesghali
ali
Gold Beach, Oregon
After long research, I figured it out.
The CMSL auxiliary wire is located just behind the wheel well cover directly at 12 o'clock. It's an ORANGE/GRAY wire tucked in a harness.
NOTE...
This wire is only energized when the ignition is ON. Pressing the brake pedal with the ignition OFF will still light your brake lights, but the CMSL will not light up. This is problematic and can cause a false fault.
The Key Fob wire connection are made at BCM connector C2280C, pins 32 and 35.
Pin 32 = All Open (GRN/BRN)
Pin 35 = All Lock (GRY/BRN)
Ford F-150 Lightning CHMSL Center Brake Light Wire for Cap Topper & Fob wires location 20240727_192214
Ford F-150 Lightning CHMSL Center Brake Light Wire for Cap Topper & Fob wires location 20240727_192240
Ford F-150 Lightning CHMSL Center Brake Light Wire for Cap Topper & Fob wires location 20240727_193740
ALL LOCKED / UNLOCKED WIRES
Ford F-150 Lightning CHMSL Center Brake Light Wire for Cap Topper & Fob wires location Screenshot_20240902_000122_Chrom
Ford F-150 Lightning CHMSL Center Brake Light Wire for Cap Topper & Fob wires location 20240904_194912
Ford F-150 Lightning CHMSL Center Brake Light Wire for Cap Topper & Fob wires location 20240904_184735
Ford F-150 Lightning CHMSL Center Brake Light Wire for Cap Topper & Fob wires location 20240904_184807
Ford F-150 Lightning CHMSL Center Brake Light Wire for Cap Topper & Fob wires location Screenshot_20240901_193608_Samsung Notes
cdnphotog
F-150 Lightning Flash
That's all great information. Thanks for posting as I'm in a similar boat.
When using the wire to power the CHMSL I've noticed people referencing a "CHMSL filter harness", did you use a harness or did you just run straight to the brake light?
amesghali
ali
Gold Beach, Oregon
The filter is not needed when using the the auxiliary wire. And if you use the filter to tie into the break wires under the rear bumper, you will get interference with the factory trailer package.
cdnphotog
Ok thanks that makes it easier ?.
Out of interest why would someone need the filter?
Is there anyway to access marker and reverse lights? My cap has both (I can due without the signals)
amesghali
ali
Gold Beach, Oregon
Because Ford uses the same bulb for both brakes and turn signals. The diode filters out the turn signals. Without it, your chmsl would blink when using turn signals.
I don't know if anyway to wire any of your other topper lights. These new F150 ECM's are very sensitive. You can't just tap into any wire anywhere. This is especially true if you have the towing package.
cdnphotog
How about I just have a CHSML alone!
… at least until someone comes up with a solution…..
Thanks for saving me some headache ?
B177y
Olympic Peninsula, WA
2024 Pro SSV ER Max Tow
NOTE...
Did you remove the frunk to get to the brake light wire or did you remove the wheel well liner and access it from underneath?
amesghali
ali
Gold Beach, Oregon
Just remove enough screw on the wheel well liner to be able to pull it away and get to the wire. No need to remove the entire liner. Nothing to do in the fronk either.
