Bakflip MX4 install, am I doing it wrong?
mikev80
f150 lightning flash
I cannot get the rail flushed properly with the clamps. It almost looks as if the foam strip is not cut to the right size and just allowing my rail to sag. Did I get a defective one, wrong model, or I’m just not doing it right?
When holding it up by hand you can see the gap where the foam contacts the truck:
Ford F-150 Lightning Bakflip MX4 install, am I doing it wrong? IMG_1693
Ford F-150 Lightning Bakflip MX4 install, am I doing it wrong? IMG_1687
AZT9
Peoria, AZ
You need the clamps to “push” it against the bedside. Two sets of hands make it easier
Ford F-150 Lightning Bakflip MX4 install, am I doing it wrong? IMG_8093
Ford F-150 Lightning Bakflip MX4 install, am I doing it wrong? IMG_8094
Ford F-150 Lightning Bakflip MX4 install, am I doing it wrong? IMG_8095
mikev80
Thanks for the pictures! Our rails look different. Yours doesn’t have a foam to press against the truck bed. I wonder if I should remove that.
AZT9
Peoria, AZ
Looks like a slightly updated design but the metal rail shape looks generally the same. It was a while ago but if I recall. The foam was not installed on my rails and in the packaging. I really don’t think it’s necessary to be honest. I would say remove it and try again. Worst case a little spray glue and it’s right back on if needed. I does take a bit to get the rails aligned once the clamps are on. I got both rails on with the clamps not loose but not too tight, the mounted the cover to aid in alignment as the cover on will square the rails. Then buttoned up
The clamps
Hope that helps ??
mikev80
I figured it must be updated design too. But man, the clamps just pulls it down some more. The rails and clamps look different from the 2 videos I’ve found and your picture.
AZT9
Peoria, AZ
I do recall it was a bit of a PITA getting the rails to cooperate too. Hope to see it installed soon!
AZT9
Peoria, AZ
Maybe double check the model# on the box shipped as a cross reference for the proper kit
CRAIGC540
Craig
Moreno valley
Technician
I had the same problem, you need to call BakFlip and ask for shims.
CRAIGC540
Craig
Moreno valley
Technician
My work mate had the same problem and gave me his extra shims. I did call them and they sent me a set. They should really send shims with the covers.
Realtruck
Diamond Sponsor
RealTruck
2022 Ford F-150 Lightning
Thanks!!!
I hope you were able to get your shims for the install. Feel free to PM me if you still need help with this!
