Need Help understanding how to install new subwoofer and amp to 2022 Lariat with B and O
Glendawg619
Glen
2022 F150 lightning Lariat, 2022 Tesla model 3
Electrcian
Hello, I recently purchased these items
Sub box and Amp Combo : https://www.amazon.com/KICKER-48CDF124-Subwoofer-Enclosure-Amplifier/dp/B096YDYDKW
LC2I converter combo : https://www.amazon.com/AccuBASS-2-C...-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
I am aware that I will have to run 8 gauge power and ground to the battery in the frunk, but the rest is a bit confusing to me. Does the stock B and O amp already have low or high level input going into the amp that i would be able to steal to feed the new amp? or will i need to still splice into a speaker wire? Is there any other hardware that im missing to complete the job? any help would be greatly appreciated
Andrewbens
Modesto
Lightning
Mechanic
daczone
2024 Lightning
LC2I converter combo : https://www.amazon.com/AccuBASS-2-Ch-Line-Out-Converter/dp/B0CGRZJGCH/ref=sr_1_1_sspa?crid=2UWN3TT62L6PU&dib=eyJ2IjoiMSJ9.xLzVPpo0TwJn47DGPEiB1VekB3IF0LT_15Gm-x90ISvFB45RZ49TKp8BYgQL4VQteztBfBKVeY_hPxVJ3fikcZAN3vQLs1KiAa4FFAXk_JfRNAP8rxFXKF9JehNpqp-w8-eemlEKnTO9F05aZkjs6q5lza3Sa9XbsIw4eKUwSYAd0L98knwC8LJJnenwOqzRE_ZCFB0yRMuE-1UOn8PiB8g8xfApBTHSw622ShHzRVK669-O4msIZeKH4Ifp9cxqJPCjYMTdv4ovkPEADlKrSQJscO691Nm6kV-wgVJJtpw.2y6R0GvCUJGfi186lkc-4ONE7i3P0gFrgkmnVzvlW6k&dib_tag=se&keywords=lc2&qid=1732668273&s=electronics&sprefix=lc2,electronics,195&sr=1-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
If you haven't done this yet:
Add a Subwoofer to your B&O Lightning
You basically have 2 options. Grab the existing signal going to the factory subwoofer. Which will need to go through some sort of line converter (I used the Kicker KEYLOC). Or intercept the signal before the Amp with a harness (Shown in the link above) which still would need a line converter. The difference is bypassing the factory bass cutoff that the B&O system adds/removes to the signal.
