12v outlet in truck bed
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
A 12v battery in a battery box and a 120 charger plugged into the outlet, will charge when the truck is on. or solar panel and controller..
They also have a remote control that will power a relay that will wireless control your fan from the cab.
I was using a 12v 35ah gel battery and charger to run my bed cover before I hardwired it.
Rick
Tom Jensen
Tom Jensen
Arlington, Virginia
F-150 Lightning 2023
Attorney
Rick
RickL - Thank you. That’s a simple set-up. I have all those items except the fan with remote somewhere in my garage. Is there a fan/remote combo you’d recommend?
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
The fan would be your choice.
Wireless remotes are a dime a dozen on amazon. I've used 6 channel remotes on my jetters and did far better with a sub $100. Remote than the factory jetter remotes that cost thousands.
A simple 2 Chanel remote from amazon is cheap. Here is one I just looked up for $14.99 has 2 fobs and a 30amp rated relay.
Rick
https://www.amazon.com/Wireless-Cur...fix=wireless+remote+control+12,aps,170&sr=8-3
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Cleanup would be much easier if you trade up to a PRO ... :rolleyes:
Tom Jensen
Tom Jensen
Arlington, Virginia
Attorney
Thank you. I freely admit to being a bonehead for not thinking of this approach.
