Of what use is Off-Road display of steering angle, tilt or yaw?, pitch?
GoodSam
Good
occupying space
I rarely go off road, except for a couple of camping spots and do not usually show the Off-Road display parameters on the right side. I finally noticed it showing how the steering angle moved in the front of the picture while I was turning but stationary. There is also the degree of tilt? indicators on each side, and I assume the pitch angle front to back is indicated at the rear of the bed. I cannot think of when the steering angle would be that important to know. I guess the side to side tilt (or is it yaw about the center of the truck? Hmm, that would not make sense?) and forward/back tilt would be good if one was going to sleep in the bed area. Any other important uses? Thanks for helping me understand the display.
Ford F-150 Lightning Of what use is Off-Road display of steering angle, tilt or yaw?, pitch? IMG_20240325_103318488
Adventureboy
The display is only important if you are doing serious off-roading. It can be quite useful in those situations. The steering angle is useful in really deep snow.
Otherwise, it's just a cool gadget the truck can show since it has all of the sensors for stability control anyway.
If you go off roading then you'll know.
I use it mostly for crawling up/down bumpy trails. Before, if you lost track of where the wheels were pointing you'd have to stick your head out the window. Most people won't ever use the feature but it's helpful in some situations.
GoodSam
GoodSam
Good
occupying space
Discovered how useful this is for camping with rooftop tent!!!!
But I do not think there is a complete description written (or video) of what the side and rear end degree indicators are for?
Jamchampnate
Nate
Utah
Ford lightning 23’ Lariat
Sorry, I’m not following what you’re saying. Each shows the angle that the axis it’s on is angled at.
GoodSam
GoodSam
Good
occupying space
The front is steering degrees horizontally left or right. But are the Sides and Rear degrees horizontal or vertical? I would guess they are degrees vertical? Sides would be inverses of each other? I just would think @Ford Motor Company would have an information page on these angles...perhaps I have overlooked that information. Anyway, not going off-road enough to notice...would be cool to have a "heads-up" display of this info so as not to take eyes off the road.
capt_ramius
Sean
St. Louis
2022 XLT 312A
If you do any kind of camping in your vehicle, then knowing when it’s level is absolutely priceless.
