Ordering Bilstein 6112 Kit
haroldt
Harold
2023 F150 Lightning Lariat ER in Azure Gray Metallic Tricoat
For those that ordered the Bilstein 6112s, which drivetrain option did you select at checkout? I'm wondering if there are different spring specs based on the different drivetrains.
I just ordered off shocksurplus.com and selected 4wd with the Powerboost. My reasoning based on that being the heaviest drivetrain, and closest to the weight of the lightning.
Thanks!
dr1983
dennis
2022 Ford Lightning XLT
Security Advisor
I have a 22 XLT, I put 6112’s and rides so much better. Don’t get me wrong I liked my mom’s Caddy and that floating feeling but not everyday. These trucks float alot in the front. I also put tuff country uni balls on it aswell to keep everything within spec. Awesome all the way around.
Ford F-150 Lightning Ordering Bilstein 6112 Kit IMG_1750
Ford F-150 Lightning Ordering Bilstein 6112 Kit IMG_1748
Ford F-150 Lightning Ordering Bilstein 6112 Kit IMG_1749
Ford F-150 Lightning Ordering Bilstein 6112 Kit IMG_1752
Ford F-150 Lightning Ordering Bilstein 6112 Kit IMG_1753
haroldt
Harold
Looks great @dr1983! I love the color of your Lightning!
Did you do the install yourself? My 6112s should be shipping out this week (#5 height setting) and I'm stoked to put them in. I was considering upper control arms as well... Are the Tuff Country uni-ball arms the most economical option? I don't need anything crazy, just want to optimize geometry like you.
dr1983
dennis
Security Advisor
Thank you and yes took me 3 hours, i removed the cv axle from the knuckle, the sway-bar and the steering arm. Then removed the upper control arm and the brake line bracket and the abs pins. and let it rotate back and the lower arm held it up enough. yes the tuff country are the better ones I have them on my Titan XD and they are really great compared to the rancho control arms that always squeaked.
haroldt
Harold
@dr1983 I was about to buy the Stuff Country UCAs when I saw this note in the product description:
"Requires aftermarket wheels with 5" backspacing or less"
I notice you have aftermarket wheels. Wondering if anyone has tried these control arms when. The factory wheels?
haroldt
Harold
According to these specs, my Lariat wheels measure 20*8.5" with +45 offset:
Ford F-150 Lightning Ordering Bilstein 6112 Kit 1000010247
Putting that into this calculator tells me that they have 6.52" of backspacing, which is definitely more than the 5" maximum for the UCAs:
Ford F-150 Lightning Ordering Bilstein 6112 Kit 1000010246
I will probably just go with the factory UCAs until I change wheels later down the road, unless someone knows of UCAs that are compatible with this much backspacing.
dr1983
dennis
Security Advisor
my nissan titan has stock wheels and they say the same thing but work just fine
dr1983
dennis
Security Advisor
Putting that into this calculator etells me that they have 6.52" of backspacing, which is definitely more than the 5" maximum for the UCAs:
this just for reference, This is my Titan
This is for reference, this is my titan xd
Ford F-150 Lightning Ordering Bilstein 6112 Kit IMG_0438
