Charging stations display
  • Thread starter Deleted member 20178
  • Start date
  • Watchers 1
Guest
Is their a way to show charging locations on navi while driving. For instance my EQE, Taycan shows chargers and availability as you driving?
Scorpio3d
SS/IBA car wash owner
I assume you mean in the Ford Sync system?
It has been a while since I have used it, but as @Heliian said you can search and filter in the Ford NAV system. if you put in a destination, it will show you your range with a blue circle and chargers along the way… as I said, it has been a while since I have used it so I apologize if that’s not exactly correct, but it should be close
Guest
Yes that i understand i was just asking if it comes up automatically on your navi as a icon with chargers availability. No route set or anything else just driving. But it seems it only works when route is chosen. Thanks
Scorpio3d
I could not remember if it would work(show chargers) without putting in a route. That’s why my answer was kind of vague. It seems like you should be able to do it without putting in a route, but it is what it is…
PlugShare and I think ABRP you can kind of look around maybe some others I can’t think of right now
Charge_Rob
2024 F-150 Lightning Lariat
Charging Nerd
Yes, you can search for chargers in Connected Navigation near your vehicle, near your destination, or along your active route. You can see availability data for in-network locations in Connected Navigation or by using the Public Charging app.
