RedTib
Michael
2024 F-150 Lightning Lariat
If that harness is the expensive part, I will wait until junkyards have more Lightnings and buy for less than $500.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Yea, also, once Lightnings are in junkyards where you can pull your own parts, you can pull the hose connections, the electrical connectors and the Inverter, basically everything you need to install the inverter. I think there is a real gap in the market for salvages to do this kind of thing. Even going as far as packaging/kitting all the pieces needed and selling it as "Pro Power 7.2 upgrade for Lightning"
RedTib
Michael
On eBay right now, if you search for VIN 1FTVW1EL7NWG05344, it looks like it is a parted out Lightning with PPOB. Don't quote me on that, but it looks like it has the wiring harness for $250 and the DC converter for $630.
123XYZ
SF Bay Area
2023 F-150 Lightning Pro
$1500??? Is the orange color because it's doped with gold, wtf? I get that it's likely low O2 high strand count copper (correct me if I'm wrong here) HV rated, despite most cables I've seen being 600V anyway, that leaves the connectors, maybe $250 in wire, $1250 for connectors? Am I missing something?
Edit: I was seriously considering doing this until I saw this ridiculousness.
The MSRP for a single headlamp assembly is $1,507.63. By comparison, $1.500 for a wiring harness seems cheep. But the need to replace the HV wiring harness largely convinced me to abandon this idea.
Full disclosure: Some Ford dealers will sell you a headlamp assembly for a bit under $1000. What a bargain!
chriserx
Louisiana
I almost understand the cost of the headlamp, especially considering they include the matrix type lighting. Weird they added it since the primary market disallowed at the time of introduction iirc. I assumed that the 'harness' was just to the inverter, in which case the price is still ludicrous. But if it were to attach at other points then I could see it, I guess...
123XYZ
SF Bay Area
It's one of several parts of the HV DC wiring harness. I don't think the inverters are the only parts it connects to, but I don't know what else it attaches to.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
It is the entire rear DC Harness, with distribution box and all components that touch the DC bus, including the rear drive unit. That's why it's so expensive. This wouldn't be an issue at all if Ford didn't Tier 1 restrict all the connectors with their suppliers. They do this so they can pick and choose which connectors to offer as repair parts, and charge 10-20-and even sometimes 30times the amount it should cost if the supplier sold it on the open market.
123XYZ
SF Bay Area
Is this rear harness entirely limited to the area under the bed? The idea of replacing a wiring harness gives me visions of what Tesla wanted to do with my Model S to replace one slightly gnawed wire between the HVAC controller and an A/C valve, which would have entailed almost complete disassembly of everything but the body panels, large structural members, and suspension (removals included the 12V battery, propulsion battery, all seats, center console, everything in the dash area, which is a LOT of work, the frunk, etc.) and cost several thousand in labor. I passed on that repair.
If I can replace the rear HV harness with one from a salvage yard once I remove the bed without a lot of hassle disassembling the cabin and dealing with trim that I inevitably make a mess out of, maybe I should put this back on my to-do list, but it'll still have to wait until I'm done with spring work planting in the vegetable garden working on the lawn.
mr2urbo004
CA
2023 Ford F150 Lightning Pro, Tow Tech,
Hopefully you can find one so I can get this done too.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Mostly yes, with the bed removed it can be 100% accessed and swapped easily/quickly. The only part that runs under the cab is the connector that plugs into the front of the battery and runs back to the HV Junction Box.
22legit2quit
2024 Ford Lightning Flash ER
I haven’t read everyone’s responses, but it seems like getting the home integration system (assuming it works) would be more cost effective and safe.
someone with more electrical knowledge than me could say whether or not that would work. I’m not as read up on the bidirectional power that the lightning can provide on that system. I’d assume that since you can by the integration system with multiple levels of inverters that the truck is just a power bank and input/output would be based on the inverters capacity.
From a value standpoint, I can’t see that adding this would give you any more value resell or otherwise. Adding that capability to your residence should be either deductible or a credit on your taxes at least in the US.
For safety I can’t see that this would be safe for most people to diy, if it was a simple plug and play it would be a different story.
mr2urbo004
CA
Get this.
https://www.sigenergy.com/
ZSC100
Zach
Tulsa, OK
Electrical Engineer
It's a great option, but there are many reasons why people may not want to go this route.
Some non-starters for me are.
I need the power to be mobile. I have multiple houses I stay at as well as my family, we all have generator hookups living in the Midwest.
2nd, 100% of the cost of this mod can be added to the vehicles net worth.
And third, I'm not paying Ford a dime for any subscription services.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
This just in: I'm ashamed that I started this mod thread over 3yrs ago now and still to my knowledge no one has done it yet. I am currently working on this again just recently and hopefully will have it figured out soon:
https://www.f150lightningforum.com/...rter-pro-power-onboard-9-6kw-technical.36705/
@mr2urbo004 is sending me the AC Power Outlet Box (Bed Box) and I have everything setup on a test stand. I'm currently trying to navigate what module configurations need changed to make A: and B: phase power readouts scale to 3400W. Mine is still at 1200W:
Ford F-150 Lightning Installing Pro Power Onboard 9.6kW Inverter - OEM 1778192807631-pi
I hope @Jesse-Infotainment can help with this, at least to help understand how/why Ford did what they did here. They call this inverter GFM3 as far as module acronyms go and there is a configuration for it, but no-body knows what any of it means.
As soon as I get this Bed Box and test it with the LIN control I'll report back. I also have a LIN analysis tool ordered, so if this doesn't work I'll figure out why.
Lastly I have a solution to not purchase/replace the full HV wiring harness, that has ben the economic killer of this mod to date. The cooling just goes in series with all 3 modules under the bed, that's the easiest part of the entire thing.
@123XYZ did you ever attempt any of this? I'm curious too if any others on this thread attempted ANYTHING related to this mod.
Thanks,
Zach
