Found a great replacement tire … Kumho Road Venture HT’s
bluey2025
Shane
Cape Coral FL
2025 Antimatter Blue XLT
Fleet Manager
Living in SW Florida heat… shell roads… and spirited driving have quickly taken a toll on the Michelin Primacy XC tires that my 25’ XLT left the factory with. 15k miles and closer to the wear indicators than I cared for to be driving in Floridas rainy season.
Last month I installed a 2 inch leveling kit so I was already in the market for tires. I love Coopers and Toyos but didn’t want the hear the All Terrain drone in what should be a quiet and comfortable truck. So after lots of research I found what I think was a nice EV RATED upgrade. I ordered at set of Kumho Road Venture HT’s. They are an LT, EV Rated highway tire that also meets the qualifications for a 3 Peak snow/ice rating. They look and ride very similar to a Michelin LTX MS.
I bumped up my sidewall height and load rating and went to an LT275/70/18 just to get a little more height without affecting range or ride quality. They have only been on a day so far but fit great, ride great, steering responsiveness is improved over the mushy Michelins and as far as I can tell… zero changes in my range but time will tell as I build a new average after resetting everything.
Just figured I’d share some feedback… I’ll comment more over time.
Ford F-150 Lightning Found a great replacement tire … Kumho Road Venture HT’s IMG_4627
bluey2025
Shane
Cape Coral FL
Fleet Manager
That’s what I was worried about and so far I’ve got zero complaints.
bluey2025
Shane
Cape Coral FL
Fleet Manager
These look like a great option and the price is right. I know will need a new set before winter so these are a top contender for sure.
I agree. The price point is great and they literally tick every box.
TonyCO
2024 Lightning XLT
I like those tires. I’m actually thinking of going with an LT if I keep this truck. The ride is so soft on the stock tires I’m thinking an LT might be perfect? Does that thought process make sense to anyone?
JimmySasquatch
James
Indiana, USA
23 Lariat ER
Yet, lol. I put LT tires on my other truck and thought the same thing. After driving my new truck, the last thing I want to do is have to drive the old one. Looks great and I'm sure the beefier sidewalls have saved themselves over the years of skinny drive thru scrapes and the like.
The harsher ride alone is a non starter for my old worn out back.
What tires are you looking at?
bluey2025
Shane
Cape Coral FL
Fleet Manager
It was my thought process and I’m enjoying it. The overall ride is ever so slightly stiffer but in my opinion it’s not noticeable enough. The LT’s do shine when it comes to lateral stability. My steering feels smoother and more responsive. Range so far… I was averaging 2.3 mi/kwh. I’m seeing 2.1mi/kwh now. But I also went from a 275/65 to a 275/70 for a jump in height to match my leveling kit. In my opinion the slight loss isn’t a concern of mine. I was averaging out 260 miles on a charge when charging to 100% which we all know our dashes are guess o meters but now I’m reading dead on at 240 since I decided to charge to 100% last night to see. Personally, I think these trucks should have been equipped with an LT tire from the start. Mine ate my soft Michelins alive. Too much power and weight for a standard tire. The Kumho’s track very straight and feel solid especially on a WOT pull.
potato
BC, Canada
2023 F150 Lightning XLT ER
Did you correct the speedo/odo for the change in tire size?
WaterboyNorCal
Erik
NorCal
2023 Ford Lightning XLT SR
Nunya business ;)
Makes sense to me! I got some Cooper Discoverer AT3 XLT tires for winter use and loved them. Yes, sidewall is stiffer, which makes handling feel much better. There was a ~5% efficiency drop but probably mostly due to a more aggressive and deeper tread pattern. I love the idea of an EV-tuned LT tire to (hopefully) offset the range hit.
mwdietert
PA
2023 ER Pro SSV
Perfect timing to see this, ty OP. I placed an order on TireRack yesterday for this set for my 18" PRO SSV and couldn't find any real world reviews yet.
GarageMahal
JT
Data Wrangler
Thanks for sharing these, 3 peaks, quiet and affordable! On my short list when I replace tires this fall.
