Pics and range info: Eibach 2.6” leveling shock and KO3 295/60/20 tires on Lariat ER
surlymcm
SC
23 Lariat ER order. 23 Taycan 4CT, 04 E 320 wagon
I finally wore the OEM hankooks enough that I didn’t feel bad replacing them. After doing some homework as well as looking at different tire set ups on other F 150s I decided to go with a 295/60/20 KO3 on stock rim with a 2.6“ Eibach leveling front shock. That’s a 33.9” tire weighing 65 lbs with a max load of 3,750 lbs and max psi of 80 vs the hankooks which are 32.8”, 41 lbs weight, max load of 2,679 lb and max psi of 51. In short a LOT more tire. Install took about five hours at my local shop including shock alignment recalibrating blue cruise which was throwing error messages. No rubbing at all. Ride is stiffer in a good way. Now it rides like all my other gas F15Os not like my grandmas Lincoln. Bouncy floaty feel is gone and it feels much more planted and connected to the road.
Tire shop set them at 41 psi and I haven’t messed with that yet so range info is based on that pressure. All of my driving is done around town. I reset trip 2 odometer when I left the tire shop and have since covered about 500 miles. On stock tires I averaged 2.3 mi/kw now I am getting 2.0. Range is down from 320 to 275. So that’s about a 14% hit. To me it’s totally worth it. Still dirt cheap to drive vs my old truck and now it actually looks and drives like a truck. NO regrets!
Ford F-150 Lightning Pics and range info: Eibach 2.6” leveling shock and KO3 295/60/20 tires on Lariat ER IMG_4654
Ford F-150 Lightning Pics and range info: Eibach 2.6” leveling shock and KO3 295/60/20 tires on Lariat ER IMG_4653
Ford F-150 Lightning Pics and range info: Eibach 2.6” leveling shock and KO3 295/60/20 tires on Lariat ER IMG_4652
LSUT1GER
Slidell, LA
Computer Engineer
Could you list the components and prices for what you did to get rid of the bouncy ride?
surlymcm
SC
Shocks are Eibach part # E60-35-061-01-10 set to the max height of 2.6". 295/60/20 KO3 tires. Shocks are around 300/pair and tires were 2100 for the set. Labor was 900 to install shocks,mount tires, align front end and recalibrate sensors.
And PLEASE beat clemson saturday!
LSUT1GER
Slidell, LA
Computer Engineer
Only the front shocks or all 4? Did you also replace the springs?
Geaux Tigers!
Adventureboy
Ontario
Looks good. I might do the same when my current rubber wears out. How do you find the road noise with the KO3?
About 3% of your apparent range reduction is because of the larger tire - you'll cover more ground every revolution and it will appear as a range reduction unless you correct for it. Your actual range reduction might be 10-11%. Very acceptable for a good set of tires.
surlymcm
SC
Everything I did is detailed above.
surlymcm
SC
More noise than stock but not bad at all. Definitely less than the grapplers I had on my old truck
