Stage3Motorsports
In stock and ready to ship, message me for Forum pricng and also if purchased by 11/22 get entered into our $2500 shopping spree giveaway!
2017-2021 F150 & Raptor 3.5L EcoBoost K&N 63 Series Cold Air Intake 63-2599
Highlights:
You can always trust the brilliant intake engineers over at K&N Filters to design something special for your Ford F150, and the 63-Series AirCharger Air Intake Kit does not disappoint. The system is made up of specially formed roto-molded plastic and is designed to fit the Ford F150 EcoBoost. Adding a cold-air intake is a perfect way to get some easy power and performance gains for your car or truck. The 63-Series intakes are up-gunned versions of K&N's more standard cold air intake kits. K&N intakes are designed to dramatically reduce intake restriction as they smooth and straighten air flow, allowing your vehicle's engine to inhale a larger amount of air than the restrictive OEM air filter assembly. On top of their impressive power gains, this Cold Air Intake Kit improves fuel economy and throttle response, making it one of the most effective upgrades you can grab for your vehicle.
K&N Dyno Results: +12.3 Horsepower Increase
Fits The Following Models: 2017-2021 Ford F150 & Raptor 3.5L EcoBoost
Performance K&N Filter with Heat Shield and Inlet Tube
When they designed their 63-Series kits, K&N dug up the largest air filter that they could possibly fit in place of your truck's factory air box and built the rest of the system around it. The filter is one of K&N's classic high-flow oiled systems that brings in a much larger volume of air than stock along with improved filtration. Along with the filter, each K&N 63-Series kit comes with a full heat shield assembly and a highly efficient inlet tube that works together to promote improved airflow into your ride's engine over the stock air box.
Installation Note: Included in this kit are detailed instructions for a relatively quick and easy installation (takes approximately an hour using standard tools).
Highlights:
- Adds top-end power and response to your truck
- Features high-flow oiled air filter, inlet tubing, and heat shield
- Drop-in replacement for the stock intake
- No tuning required
- Comes with hardware, couplers, and instructions
