Stage3Motorsports
S&B has revised their 5.0 Intake to work through the 21 (most likely 22) model years.
(web inventory hasnt updated yet but 9 in stock at the moment)
2018-2021 F150 5.0L V8 S&B Cold Air Intake Kit (Oiled Cotton Filter) 75-5123
Highlights:
The big, bad Coyote 5.0L V8 under the hood of your 2018-2021 F150 craves more airflow and wants to breathe, but gets choked off by the fairly inefficient factory air box. S&B's Cold Air Intake Kit is here to help get your 5.0L a bunch of extra air to give your truck an improvement in horsepower, torque, throttle response, and fuel economy all in one place. S&B's Cold Air Intake kit is a total overhaul of your F150 5.0L's intake system and allows your aggressive truck to breathe easier for an overall improvement in performance. Each S&B intake kit comes with a complete air box assembly, high-flow air filter, inlet tubing, and hardware that all drops on right in place of your factory intake system without the need of any tuning or other upgrades. Like all of S&B's intake systems, their F150 5.0L Cold Air Intake Kit is made from high-quality materials, so that it can handle any application or climate while delivering excellent levels of performance.
Features a Complete Air Box, Filter, and High-Flow Tubing
Each of S&B's cold air intakes is 100% complete and comes with all the hardware and components you need to overhaul your 5.0L F150's intake system. The kit is built around an S&B high-flow cotton filter made with silicone bases and tops that won't crack like the competition's polyurethane filters. The filter's cotton media can be cleaned, reoiled, and reused for the life of your truck. The filter is housed in a complete air box assembly that features a larger and more efficiently sculpted forward air scoop than stock to help improve overall airflow volume. The filter feeds air into a highly efficient inlet tube assembly that greatly reduces restrictions and back pressure and is locked tight to the air box with a full silicone seal to help prevent heat soak and NVH. The air box of each kit comes with a clear lid that allows for easy viewing of the filter for maintenance checks. Each intake comes with a complete set of hardware and instructions.
Highlights:
- Improves throttle response and top-end power
- High-Quality Silicone Filter with Oiled Media
- Includes enhanced inlet tubing and air box
- Silicone Couplers and Seals for Improved Durability
- Made in the USA
- Backed by an S&B Million-Mile Warranty
