Added Factory Trailer Brake Controller to 24' Flash
TylerEggs
Tyler
2024 F150 Flash
Hey everyone,
I've been reading the forums here for some time and finally got around to adding the brake controller to my 2024 Flash trim. My truck came with no listed towing packages, but it did come with the trailer backup "assist" knob.
After reading, I decided I'd start with just trying to add the Trailer Brake Controller in the dash (ML3Z-14529-AC) which ran me about $75USD. So, I popped it in (and I should mention I'm decently proficient with Forscan) and opened up the module and enabled Trailer Brake Controller and a couple other ones (there's three bunched together). For the record, the black box under the dash at the time was the factory one (ML3T-19J295-GA).
What happened after is kinda what I expected, which was basically nothing. The towing screen would show the gain adjustment level, but the buttons on the controller wouldn't do a thing. So, my next step was to order the module that goes under the dash. I popped onto eBay and bought a used one that I believed had the correct guts to actually control the trailer brakes (MU5T-19J295-HJ) and I got that for $64USD. It showed up, two harnesses to swap and a quick 30 seconds later the new one was in. I tried the brake controller....still nothing.
The key was changing the values associated to the attachment below. I can't remember who posted it, but it is pure gold when it comes to enabling this correctly.
I made the changes the highlighted values and the trailer brake controller came to life. I've tested and verified with a travel trailer that it now works. $140USD instead of $240 USD for the "Kit" (RL3Z-19H332-AA).
Hopefully this helps !
TreatYoSelf
Colorado
2024 F150 Lightning Lariat - 2020 Tesla Model 3P
Ad Man
Thanks for sharing! I think adding this to my '24 Lariat would be nice.
I don't have Forscan, but I've used similar software for Volkswagen and BMW. @TylerEggs Forscan's website says that 2024 models are not supported. I've been putting off Forscan because of this, but clearly it's working with your '24 Flash. How did you get Forscan working on an "unsupported" model?
Paulb55
Paul
2024 Lightning Lariat
I havent used tried to add the trailer brake, but I have a 24 lariat and forscan worked no issues.
TylerEggs
Tyler
2024 F150 Flash
I didn’t realize that FORScan even said it wasn’t able to work with 24’s. I’ve had zero issues with it on my 24’ Lightning and 24’ ICE F150s. I use it the same way I’ve always used it, just plug and play.
If you’re comfortable with other technology, FORScan is pretty user friendly with lots of tutorials out there.
I see a couple of possible issues with your highlighted changes. Did you consider the current setting and just change the bit or did you just paste in a value that some other vehicle used?
The reason I ask is you have values that don't exist on any Lightning. I have created a database of over 50 Lightnings for every year, trim and most options - and some of your values are unique.
My concern is you may have disabled a feature that you should not have.
720-07-01 xxxx x*xx xx--
Lightnings with Tow have an "A" and without have a "2". Your "8" has disabled the Digital Gauge Interface.
If you had a "2" before, you should have "A" now to enable TBC.
Ford F-150 Lightning Added Factory Trailer Brake Controller to 24' Flash 1741799715607-jz
791-01-02 xxxx x*--
For 2024, trucks with MaxTow have "5" and without have a "4". Pros have a "0".
Your "1" has disabled the PSCM.
If you had a"4" before, you should have a "5" now to enable TBM.
Ford F-150 Lightning Added Factory Trailer Brake Controller to 24' Flash 1741801332665-tr
The rest look plausible and match other Lightnings.
TylerEggs
Tyler
2024 F150 Flash
791-01-02 xxxx x*--
for my 791-01-02 line, my as built data matched that of a Pro, where the value in the * spot was a 0.
as for my 720-07-01 line, I’ll have to dig back and see what the as built value was.
as far as things go, there have been no error codes and the controller works flawlessly. I’m definitely interested in what you’ve mentioned though. As mine is a “flash” and not a “pro”, do you think that there might be hope for the “pro” owners out there if these values work ? Just based on that 791 line to start.
I have not been keeping up with all the mods - it seems that 2024's have had more things to do with these mods like adding wires.
It's odd that your As-Built had a 0 there. The '22 and '23 trucks had either a "0" or "5" matching what you see. Not sure why the "4" option appeared just for 2024. Did you have a real early build 2024?
Here is my database of just 2024's. Byte 6 is highlighted in red. Green are check digits which can be ignored. I realize I don't have the Tow Tech package broken out. Edit: Factory Trailer Brake Controller included with MaxTow in 2024.
Ford F-150 Lightning Added Factory Trailer Brake Controller to 24' Flash 1741804583659-uf
TylerEggs
Tyler
2024 F150 Flash
If it helps, here’s my window sticker. Looks like my truck was an August of 2024 build. Prices are in CDN lol.
Ford F-150 Lightning Added Factory Trailer Brake Controller to 24' Flash IMG_8141
Thanks for the window sticker, I added you to my database.
FYI, when I pulled your As-Built just now, it shows the value of your 791-01-02 is 1011-34F0. So you did have a 4 (not "0") there previously and you should make it a "5" not a "1".
Ford F-150 Lightning Added Factory Trailer Brake Controller to 24' Flash 1741811748253-rt
And for 720-07-01 you have 8401-8AA0-401E, so you should have been good there and not change it to an "8".
Ford F-150 Lightning Added Factory Trailer Brake Controller to 24' Flash 1741812046844-uu
These online As-Builts are a snapshot in time. They are typically updated after a dealer session or an OTA. So it doesn't reflect any FORScan changes you recently made.
In 2024, they moved the Trailer Brake Controller from the Tow Tech package to the Max Tow package. The Max Tow just added additional cooling and now the Trailer Brake Controller. You don't have the additional cooling so just be aware of that in any changes.
So in the table I posted above, any truck with the MaxTow option had the TBC (plus Platinum which has MaxTow standard).
priceb
Price
Western North Carolina
2023 F150 Lightning XLT SR
College Instructor
Does anyone know what the 7 means in "791-01-02 xxxx *x--"
The TRM spreadsheet only shows values from 0-3.
rbharris1
Brnadon
2024 F150 Lightning Flash
Thanks for this @TylerEggs !
I have a 2024 Lightning Flash. From the factory it included the Tow Technology Package, but not the Max Tow package.
I purchased and installed the exact same equipment you indicated (ML3Z-14529-AC and MU5T-19J295-HJ). (For reference my original under-dash module was ML3T-19J295-GA). I programmed everything exactly as you indicated with the corrections offered by @bmwhitetx . Here are the edits I made:
  • 791-01-02: xxxx x5--
  • 720-05-02: xx4x xx--
  • 720-07-01: xxxx xAxx xx--
  • 7D0-09-03: xxxx xxx4 xx--
I was unable to load my IPMA (as-built) module. Kept getting "Service procedure has been interrupted" when trying to read the module. So, instead I used the non-as-built version and switched the following from "Not Present" to "Present":
Ford F-150 Lightning Added Factory Trailer Brake Controller to 24' Flash PXL_20250812_233518060.MP
A few good things have happened:
  • The trailer brake options now appear in the tow settings on the large touch screen
  • When I press the buttons on the in-dash brake controller the instrument cluster display shows the gain going up and down
Now the issues....
  • The instrument cluster display is giving me "Trailer Brake Module Fault"
  • I'm seeing a DTC in ForScan.
    TRM U3000:1D-0B
    Circuit Current Out of Range
To troubleshoot:
  • I double checked the 7-pin trailer connector to make sure there wasn't anything in there causing a short circuit. There was not; I'm pretty sure that was the first time the little cover had ever been lifted!
  • I checked that all the fuses having to do with the trailer brake and lighting system are good. They are.
  • I tried applying the highlighted settings exactly from @TylerEggs spreadsheet.
The "Trailer Brake Module Fault" still appears.
I did not make any changes to the first three blocks listed in TylerEgg's spreadsheet, but I did notice that in my As Built the third line is set to 01; the others are 00. Should I change these?
Ford F-150 Lightning Added Factory Trailer Brake Controller to 24' Flash Screenshot 2025-08-12 at 8.12.25 PM
@TylerEggs did you have to make any additional changes beyond what was in your spreadsheet? Any thoughts on the 726 module settings? Any other ideas for what the issue could be?
Marcakeus
Marcus
St. Louis Missouri
2025 F-150 Lightning Flash
Dealership Sales Representative
I know this is an older post and likely been resolved several times but wanted to note that I recently purchased a 2025 F-150 Lightning Flash and ran into a similar situation with the Trailer Brake Controller. After installing the dash controller and turning the TBC on with Forscan I found nothing working. It would show the gain controls on the dash but when pinching the manual brakes it would say "No trailer" even though my trailer was connected. I found a used Module online off a salvaged 2023 F-150 Lightning Lariat with the integrated TBC from the factory (part# ML3T-19J295-CA). After installing it under the dash the trailer brakes came to life without needing to reprogram anything for the new module.
