Adding power mirrors to XLT
pookguy88
cars
does anyone know the exact APIM code to change in FORScan to enable the autofold option in Sync? Do I just go by Livnitup's spreadsheet?
Asking because Livnitup's spreadsheet has the wrong value for the DDM/PDM codes..
Maineiac12
Iowa
Has anyone added power fold mirrors to a 2024-2025 Flash? I’m wondering if the BlueCruise sensor in the door complicates the install? Or does the same harness work?
pookguy88
cars
I did, sensor in door is a non-issue, just unplug when doing install and plug it back it back in with the rest of the new mirror harness
Maineiac12
Iowa
Thanks! I’m on the hunt for some antimatter blue mirrors but I may end up getting another color and having a shop paint them to match.
21st Century Truck
Martin
Just switch the painted caps with your old caps. Three Torx screws under the mirror glass, and You're done.
Maineiac12
Iowa
Boosted Grey Goose’s website only lists model years 21-23 but the 24-25 don’t appear different aside from the BlueCruise sensor. When I asked them if the harness would still work I got a little bit of attitude in their response to me so I wanted to be sure someone else had done it successfully.
jcraig
Pa
2025 Lightning Flash
Maintenance
He
pookguy88
cars
yeah, the Boosted Grey Goose harness works, even though it says 21-23, can confirm
that bluecruise sensor in the mirror doesn't really even factor into the harness, the harness they/Grey Goose sells is to enable the power mirror functionality, the bluecruise sensor is separate from all that
Maineiac12
Iowa
Thanks. I was a little worried when I got pushback from Grey Goose.
beyondthelens
So Cal
Lightning Flash
I have flash and was looking into this... have you been able to find all the parts needed?
Maineiac12
Iowa
Not yet. I have the harness but I’m still looking for mirrors. It’s still cold here so I’m hoping to complete this when the weather starts to warm up.
steev182
NY
F-150 Lightning Lariat
Are people still finding power fold mirrors? I’m looking on eBay (after my driver side mirror had a fight with a sanitation truck and lost and broke the cover, camera and puddle light) and can only seem to find manual fold mirrors there.
steev182
NY
Well I ended up just getting a manual fold mirror, installed it today and everything seems to work.
I then took the original mirror’s cap off to assess the damage a bit more. The plastic sail panel cover is broken, the cap’s screw holes snapped away from the cap, but the frame seems in tact, and the connector ripped off the 360 camera and now I’m wondering if it’s possible to move the good parts over to the original mirror to get power fold back to it.
I think the 360 camera’s cable needs to be brought over from the good mirror and not just crimping the connector on. Has anyone taken the assembly completely apart and got it all together again before?
Ford F-150 Lightning Adding power mirrors to XLT IMG_6795
Ford F-150 Lightning Adding power mirrors to XLT IMG_6794
