Center Speaker: So much louder, found out why....
Storx
2022 Ford Lightning Lariat ER, 2022 Tesla Model S, 2017 Tesla Model 3
Well yesterday waiting for the family and friends to head over for the cookout, i was looking into the center speaker of my truck, since i recently found that my door speakers were installed in a botched hack job with the wrong size speakers and sheet metal screwed to the door poorly, figured i better check out the center speaker also...
Turns out it was replaced also, but its actually the correct size from what i can tell. Is this the correct speaker? or is it wrong also. Its actually one of the better brands ive heard about in audio. I just don't know audio stuff enough to know if its a good speaker or not.
Speaker installed is: JL Audio CF-350mt
From what i understand its a 4ohm speaker, because i can't seem to find an 8 ohm variant. I am under the impression the factory center mount speaker was 8ohm.
Do i need to replace this speaker also or is their a way to reduce its overpowering since it seems to be a high quality speaker replacement.
sstevetx
Steve
B&O center is 8ohm. You can just unplug it if you want, which is what many people do. If you want to keep the speaker you could probably wire in a 4ohm resistor, but I haven't tried that myself. There are 8ohm speakers you can find like the Dayton Audio PS95-8 3-1/2. However, it doesn't have the factory mount holes on it and will require some additional work to mount it.
Storx
Storx
I know the Alpine Component set i am leaning on buying has a crossover that allows dropping the dB output, curious if they have one for Mids.. that could adjust it down in power.
Mach Turtle
Central California
2021 Mach E, 2024 XLT
Bum
A midrange crossover? Steve's suggestion of a 4Ω resistor (with a suitable power rating and in a reasonably well ventilated location) will probably give you a good solution. I'm not enough of an audio expert to supply all the design details, but someone else on this forum probably is.
