• 📊 Lightning Orders List: Add Yours Inside!
  • 📊 Lightning Owners Registry: Add Your Delivered Lightning!
Email: It's tough. It's powerful. It's F-150 Lightning
ChasingCoral
Silver Spring, MD
retired oceanographer
A new email was sent to reservation holders to keep up the excitement of impending Lightning:
Get ready to get productive.
Ford F-150 Lightning Email: It's tough. It's powerful. It's F-150 Lightning Logo-Ford
Ford F-150 Lightning Email: It's tough. It's powerful. It's F-150 Lightning 8e4a17e73f8cb8979d9775cae24dbf5bfb512f6d28dc173730
Preproduction computer-generated images with optional equipment shown throughout. Available starting spring 2022. Ford Intelligent Backup Power simulation.
A powerhouse that powers your house.
Mark, this truck is a game changer. From its nearly instantaneous torque* to its ability to power your home,** driving an F‑150 Lightning will be an experience like no other. Did you know its massive frunk (aka a front trunk with charging outlets) has the ability to both store AND power your tools and gadgets on-site.† It’s time to reserve†† a truck with capabilities only electric can deliver.
Reserve Yours
*Based on manufacturer testing using computer engineering simulations. Calculated via peak performance of the electric motor(s) at peak battery power. Your results may vary. **When home is properly equipped and home transfer switch disconnects the home from the grid. †See Owner’s Manual for important operating instructions. ††By completing the reservation process, you are not ordering or purchasing a vehicle. For more information, review the reservation terms and conditions..
Ford F-150 Lightning Email: It's tough. It's powerful. It's F-150 Lightning 20100722fbf950312fd5d01ba4e672008f82fb15e969443c5b
Acceleration that excels.
Choose the extended-range battery and you’re also choosing the fastest acceleration of any F-150 yet. With a targeted 563 horsepower and 775 lb.-ft. of torque,* this truck kicks in on the job – and kick-starts your weekend. Since the all-electric motors crank out so much torque nearly instantaneously, the F‑150 Lightning is targeted to reach 60 mph in the mid-four-second range.** See ya.
Get the Lowdown
*Based on manufacturer testing using computer engineering simulations. Calculated via peak performance of the electric motor(s) at peak battery power. Your results may vary. **Targeted performance reflects current status based on analytical projections consistent with U.S. automotive publication processes. Final performance times will be available in the 2022 calendar year.
Ford F-150 Lightning Email: It's tough. It's powerful. It's F-150 Lightning abdfc9205d2bca94a862a9c1772d4781cd6c3c74d06f27a00f
Big loads call for big capabilities.
Heavy loads are light work with a targeted maximum payload of 2,000 lbs.,†† Pulling what’s behind you is just as effortless when you can count on 10,000 lbs.*,†† of targeted maximum available towing capacity. And when on-site means on the road, you’re good to go for a targeted EPA-estimated range of 300 miles†,†† – courtesy of the available extended-range battery.
See the Specs
*Max payload with standard-range battery and 18-inch wheels. See label on doorjamb for carrying capacity of a specific vehicle. **Max towing on Pro, XLT and LARIAT models with available extended-range battery and Max Trailer Tow Pkg. Max towing varies based on cargo, vehicle configuration, accessories and number of passengers. †Based on full charge. USA EPA-targeted range reflecting current status based on analytical projection consistent with U.S. EPA combined drive cycle. Actual range varies with conditions such as external environment, vehicle use, vehicle maintenance, lithium-ion battery age and state of health. Final EPA-estimated ratings available in 2022 calendar year. Excludes Platinum models. ††Payload, towing and EPA-estimated fuel economy ratings are independent attributes and may not be achieved simultaneously.
Ford F-150 Lightning Email: It's tough. It's powerful. It's F-150 Lightning 45fced757a22713cda7ea044da1ad290c3fc3d487b7ad1422d
What you need when you need it most.
Could be that your appliances need power after a storm. Your work site is down. Or you just want to illuminate the campground. Enter your F‑150 Lightning. With available Ford Intelligent Backup Power, it turns your truck into the ultimate power source.* It’s also equipped with Pro Power Onboard for 9.6 kW of power available in 11 outlets from the frunk, cab and bed.
More Power Stats
*When home is properly equipped and home transfer switch disconnects home from the grid. Based on 30 kWh use per day using the F-150 Lightning with the extended-range battery. Your results may vary depending on energy usage.
Ford F-150 Lightning Email: It's tough. It's powerful. It's F-150 Lightning aef6ca6a22ebaa43e9f3e5098e9b0fe4f25efe8dc1e9204226
Its most powerful feature is convenience.
The convenience of overnight charging is real. And it’s all yours with the 80-amp Ford Charge Station Pro that comes with the F‑150 Lightning with an available extended-range battery. Just plug in for a full charge by morning.* For the standard-range battery, you can also get an overnight charge and enjoy connected features with the available Ford Connected Charge Station. You can even schedule charge times remotely with the FordPass™ App.*
More on Home Charging
*Based on original equipment manufacturers (OEM)/automotive manufacturers that sell all-electric vehicles and have publicly announced charging networks. Department of Energy data used. FordPass, compatible with select smartphone platforms, is available via a download. Message and data rates may apply.
Ford F-150 Lightning Email: It's tough. It's powerful. It's F-150 Lightning 03ef4bbe0a71a07ab147307ef9d02f8c9092000c92f26a0125
Powerful ways to keep powered on the go.
Days can be long. Same with your to-do lists. Not a problem. When your truck needs powering on the go, you’ll have access to the Blue Oval™ Charge Network – which is also the largest public charging network in North America.* Easy to find. Easy to customize. Just how far can F‑150 Lightning take you? Explore our charging map to see for yourself.
Find Chargers
*Based on original equipment manufacturers (OEM)/automotive manufacturers that sell all-electric vehicles and have publicly announced charging networks. Department of Energy data used. FordPass,™ compatible with select smartphone platforms, is available via a download. Message and data rates may apply.
Unsubscribe | Change Email Address | Privacy Policy | CA Privacy Rights
Ford Motor Company
Customer Relationship Center (CRC)
P‌.‌O‌. ‌B‌o‌x‌ ‌6‌2‌4‌8‌
D‌e‌a‌r‌b‌o‌r‌n‌, ‌M‌I‌ ‌4‌8‌1‌2‌6‌
All Rights Reserved.
Follow Ford
Ford F-150 Lightning Email: It's tough. It's powerful. It's F-150 Lightning fb00d4ee5b7ae7dc9fc7461ad3c81139
Ford F-150 Lightning Email: It's tough. It's powerful. It's F-150 Lightning 3a332f995cf636b6953bd13ecf3962d2
Ford F-150 Lightning Email: It's tough. It's powerful. It's F-150 Lightning 1cbfe1f1d6908df8187816984f8357fd
Ford F-150 Lightning Email: It's tough. It's powerful. It's F-150 Lightning e4101a5d6cdc043e429d2923a24c4d52
Got the same e-mail but didn't see any new info.
astricklin
99 Mercury mountaineer
I feel like this should be going to f-150 owners that don't yet have a reservation?
MickeyAO
Mickey
San Antonio Tx
Lab Manager of the Energy Storage Technology Center
Did not go to the email address I reserved under, but on a separate email address I had previously had with Ford.
Diabolical!
Lee
New Orleans
'11 F250, '17 Chevy Volt, '22 Lightning (Reserved)
I got this email as well. I read the whole thing hoping for new information. My disappointment was immeasurable, and my day was ruined. lol.
F150ROD
U.S. Navy Retired
I've gotten two emails telling me Ive reserved the future and most powerful F150
Sgt Beavis
Rick
Colorado
2021 Wrangler Rubicon and 2018 Mini Cooper S Count
overpaid computer nerd.
Hmm, for some reason gmail sent it to my spam folder. I guess this is good since it made me look through that folder. I found several other messages that were not spam. Thanks Google. ?‍♂
