Features not working even though turned on!
PV2EV
After not driving my truck for a month, I am having issues with a few features (or it is the user...). It was updated since I last drove it (ECG-24.2.5.6.3 was installed on on 12/3), but the release notes are simple and this should not be the cause. There are multiple issues, but the major ones off the top of my head are:
1. Approach lighting is not working even though it is turned on in the menu. All lights work with zone lighting. Fails with both keyfobs and phone.
2. The left side door lock buttons are not working (right side does). A double pull on the handle does unlock the doors.
3. Speed Adjustment based on Speed Limit Signs is not working even though it is turned on in the menu. The signs are recognized as reflected on the dash.
The drivers door and mirror were replaced due to an impact. All buttons (except unlock) seems to be working fine, sensors/cameras were calibrated, and there are no codes stored or fuses blown, so confused about this.
Any thoughts?
I’ve had features stop working after update. Toggling the setting off and back on again fixed them.
The non-functioning door buttons being on the replaced door seems like too much of a coincidence.
PV2EV
PV2EV
Tried that and it did not work. Will try again. Tech double checked all wiring in the door and it is connected...
I think one time I had to shut them off, then shut off & restart the truck before switching back on. I should have mentioned that.
Formerly
NY
Ford Lightning 2022
Construction Estimation
It's like Microsoft Windows in the early 2000's, if you want it working better, you have to blow it away with a format/factory reset and start fresh.
