Ford App 6.13.0 Released (iOS & Android)
oldman_74
Bob
Central Florida
2024 Lightning Flash
The only thing I can say about the app that it is an app. Greatly lacking in connectivity to the truck never shows charging info and trying to save charge times settings is near impossible. It seems when charging the truck does not allow the app to connect at all. Frustrated user here Do better Ford.
K6CCC
Glendora, Calif.
Press unlock button on fob twice and hold it down and front glass will open. At least on my 24
It works on my 24 Flash, but I'm going to clarify the above description of how to do it as there could be some failure to communicate on the above description. Press the unlock and release and then press and hold the unlock button for several seconds (count to five).
Not something I expect to regularly use however.
Interestingly, this does NOT work on my '23 Lariat ER. I don't know that I would use it anyway, but I guess I don't get the choice.
Wonder if it's something they added to the 24 model year...
Lake Placid Lightning
2023 Lariat SR w/510A
Civil Engineer
Regarding global window open/close using keyfob:
I have a 23 Lariat and enabled this feature via FORScan (thanks @bmwhitetx):
Global window open/close using keyfob: only works on the front windows because one-touch is not enabled in the back windows.
  • After changes go into Sync (Settings> Vehicle> Windows) and enable Remote Open and/or Remote Close.
  • Open: press and hold the unlock button on your key fob for at least three seconds.
  • Close: press and hold the lock button on your key fob for at least three seconds.
  • Cancel Open/Close: Press the lock or unlock button again.
Civil Engineer
The Ford iOS widget that shows the charge/range status on the landscape lock screen when the phone is charging disappears whenever the Ford app is updated. I have to add the Ford widget again manually to make it reappear.
Ford F-150 Lightning Ford App 6.13.0 Released (iOS & Android) ford widget4
struckby
Richard
Atlanta, Ga
24 mach e premium hunting a lightning
Refrigeration Mechanic
Yes. It was added in 24 but you can enable with Forscan.
