- First Name
- William
- Jan 8, 2022
- rural Georgia
- 22 LIGHTNING PRO IcedBlueSilver 8/23/2022
- Occupation
- Owner
I also don't think the LIGHTNING employs any type of 'breakers', but more like FUSES, which is why you have the 'reset' buttons in the bed... so, heat does not seem to be the culprit.
I can imagine, though, that welders create different sources of nuisances to an INVERTER versus the typical tools, extension cords, and home circuits being powered by the ProPower output... while we can hope that Ford's engineers imagined every conceivable electrical tool and device to be used by the ProPower, it's also possible that the harmonics and other parts of the somewhat unique qualities of WELDING is also different than most... the process, and the electronics of the INVERTER and other equipment within the truck, may not play well together... somewhat like the condition we all talk about when it comes to the 'bonded Neutral' issue...
it should be simpler, but, well....
a gas or similar generator, though, is not designed the same... it's output is solely due to the power being generated by the running engine, and may can be much more 'forgiving' of electrical ups and downs while welding... but, a pure battery DC to 120v/240v AC output might be a different animal.
I think, too, you might search out a line conditioner, just to see...
Check if there are 'Inverter friendly' welders...
