Ford Lightning Snowplow?
Mr. Flibble
George
Seattle Suburbs
1995 Delica L400, Kia Soul EV, Jeep Diesel
Computer Nerd
I didn’t notice the Snowplow option for the Lightning. I guess that mounting kit has to come from the dealer?
GarageMahal
JT
2023 Lightning XLT SR - Iconic Silver
Data Wrangler
I don't believe there is a mounting kit for any F-150 and the snowplow option on the ICE basically adds a stronger alternator and some wiring while restricting the buyer to a naturally aspirated engine.
I am hopeful the the front frame of the Lightning is identical to the ICE versions so that existing mounts will work. Personally I am hoping to put a receiver hitch on the front so I can mount a winch when needed.
My research so far indicates that I may need to add another 12V battery or two to buffer the load that would be a wired to a 12VDC to 12VDC charger that uses less than the 80 or so auxiliary amps that should be available.
There are a couple of relevant treads on the topic here somewhere.
Mr. Flibble
Mr. Flibble
George
Seattle Suburbs
Computer Nerd
Yes, I believe that the 12v system isn’t structured for accessories. Though, it wouldn’t be hard to have a battery connected to a charger plugged into the outlet in the frunk. This way, its getting power direct from the outlet, but the battery acts as a buffer….. Now that I think about it, a capacitor might be better.
GarageMahal
JT
Data Wrangler
Here are some of the past discussions:
https://www.f150gen14.com/forum/threads/will-the-lightning-support-a-snow-plow.5567/
https://www.f150gen14.com/forum/thr...ery-power-and-ground-points.7461/#post-132860
