Front motor disengaged. No error.
Idaho
2023 lightning xlt
I've had this happen twice, once in January then again today. Soc isn't low and it's not cold or hot out. Start driving off and the power meter drops to 64. I check the power distribution screen, there's no power to the front, same with Regen.
I get to my destination and after a while being there I go back to the truck, turn it on and the issue is gone.
Heliian
Front contactor glitch.
Happened to me once in 46000kms.
Could be software related but check with your dealer as they have access to the background codes if you have connectivity turned on.
Idaho
2023 lightning xlt
Thank you, I'll go to the dealership today to see if they can pull those. Yesterday wasn't an inconvenience, able to still drive it fine, unless it's bad to drive around with the motor not engaging. But on January it was definitely unsafe because I'm in the mountains of Idaho and there was a ton of snow out, driving around in red was sketchy
Mike G
N. AL, USA
You posted back in September that you'd had reduced power messages many times since July of last year. When you went to the dealer what did they tell you at that time?
Idaho
2023 lightning xlt
October or November they replaced the air dam actuators to resolve that powertrain error. It didn't resolve it. Then went back this year, they wanted to pull codes while the maintenance light is on. They found three codes, one of them being with the shifter. They replaced something in the shifter, I want to say solenoids, and I haven't had the error since 4/18
Ford Motor Company
Official Ford Account
F-150 Lightning
Good morning, John! I would be glad to help you out with this front motor concern should you need further assistance. Just shoot us a private message with your VIN and dealer name/location, and I'll get right on it. To send a private message, just click on our username and select "Start Conversation". Thank you!
IBeTheBot
Robert
2022 F150 Lightning
IT Management
I'm having the same issue, power goes down to 51%. Had the issue on 6/26/24 and again on 7/16/24, just got the truck out of the shop and the said there were no errors, I was like here are the two photos, errors or not it is still happening.
