Lightning Front Headlight Swap
nbeasy
Nick
2024 F150 Lightning Platinum
Hey everyone — doing research on what's actually possible for swapping out the stock headlights on a 2024 Lightning Platinum. I'm not a fan of the milky white "7" shaped DRL housing and have already tinted it to get a more blacked out look, but really want to explore replacing the housing entirely.
From research I've done so far:
The 21-23 ICE F-150 projector housings appear to physically fit the Lightning fascia aperture since they share the same NL3Z housing family. The blocker is the LDCM — the Lighting Driver Control Module that sits on the back of each housing and drives everything including the bending motor, DRL, and on the Platinum, the matrix pixel array for glare-free high beams. The LDCM is confirmed to be a discrete bolt-on module that transfers between housings, but nobody has documented whether a Lightning LDCM physically mounts to a gas F-150 Platinum projector housing or whether the internal connectors match.
I also looked at the Diode Dynamics Elite Max DD5167 — fits physically but has its own standalone MCU with no CAN or LIN connection to the vehicle, so dropping the LDCM into that housing would likely generate persistent DTCs since the LDCM would find the wrong electrical loads on its output wires.
The most promising path I can see is using a used gas F-150 Platinum projector housing (ML3Z-13008-AL/AK) as a donor — it already has a bending motor and projector LED array, just without the milky "7" DRL diffuser. The specific questions I'm trying to answer:
Has anyone physically compared the LDCM mounting interface between a Lightning Platinum housing and a gas F-150 Platinum projector housing? Same bolt pattern? Same internal connector?
Is the matrix pixel array inside the Lightning housing a discrete removable component, or is it integrated into the housing structure? Could it transfer to a different housing?
Has any Lightning owner attempted any headlight swap at all, even OEM to OEM across trims?
Any input appreciated — seems like this is genuinely uncharted territory for the Lightning specifically.
A slight correction. All Lightnings have glare free, not just Platinum. So your question is applicable to all owners.
nbeasy
nbeasy
Nick
Ah yes thanks. Edited. I'm looking at part numbers and looks like all Lightnings have the same headlight part numbers, and actually the same LDCM part #s:
NL7Z-13C788-F -- the LDCM, one per headlight
Seems like the only difference between Pro, XLT, Lariat, and Platinum is all just whats enabled in software.
MountainAlive
Massachusetts, USA
I have a feeling this is going to be a tough mod. But I’ve been surprised before on this forum so who knows.
Mcfly
Billy
Socal
23 Pro SR
Realtor
The shape of the opening in the fender is completely different on 21+ F150s than it is on the Lightning. The Lightning is much closer to pre-21 F150s, but not exactly the same either.
Beat me to it, the Lightnings head light and tail light shape follows the previous gen Ice trucks. This was one of the things I hoped would change to match the current ice trucks if Ford did a mid model refresh on the lightning.
TechnoSwiss
2024 Ford F-150 Lightning Lariat Carbonized Gray Metalic
Electrical Engineer
I guess I understand why they wanted the Lightning to stand out, but honestly wish they had stuck with the stock head and tail lights, especially now that they've discontinued the Lightning. It would have been really nice to pick up any F150 head or tail light from a junk yard when a replacement was needed. Also prefer the look of the gas F150 headlights for the absence of the 7 portion of the light bar. Would be cool if somebody figured out how to make the swap.
MountainAlive
Massachusetts, USA
Totally agree for part swapping convenience. The tail light situation is also strange. I don’t understand why they had to make two different taillights just to have the rear light bar on higher trims. I would like to have the reverse lights visible on the tail lights as well as on the light bar on my lariat.
