Loud whirring sound, drivers side: AC Compr Fixed #20
JayF
JayF
Jay
Tacoma, WA
jay.jvf.cc
2023 F150 Lightning Lariat SR
Open Source Developer
Every Lightning in the south makes this noise
Including the vibration in the steering wheel? That's crazy. They did find something with mine at least so there was something wrong. I suspect the sound may be "A/C compressor at full blast" and my case might be "A/C compressor at full blast because some valve somewhere was stuck". We'll find out more when the final paperwork comes through (I'll at least make sure I know exactly what part they replaced)
jetfixr1
Anthony
Atlanta
At full blast, yes there is a small vibration that feeds back into the steering wheel. As you mentioned in your post, the temps dropped and the noise stopped. I wouldn’t worry or be surprised they say no trouble found.
Sgt. Carter
2022 Lariat ER - Star White
I’ve sometimes noticed a “whirring” sound when I turn on the a/c. I turn it off and then back on and the noise is gone. And the a/c works/has worked fine.
JayF
JayF
Jay
Tacoma, WA
jay.jvf.cc
If they found something on mine, I wonder if you have the same deal. I think it'll end up being a sticky valve somewhere, but we'll see.
JayF
JayF
Jay
Tacoma, WA
jay.jvf.cc
Finally at full resolution for this. Three total trips to the dealer, and it's fixed. The actual fix was scheduled while I was vacationing (Vegas!) so it was extra convenient. There's still SOME sound when the AC is running, but it's significantly less annoying and creates less vibration.
As a double bonus: the musty smell from my AC is gone (probably because the musty AC is gone!).
It's never "fun" to have to go back and forth to get a warranty thing fixed, but overall this was pretty good. Ford warranty paid them for a loaner when I needed it. It just took a while to get the parts and we had a false start (I took the truck in, whoops we missed a part, had to take it back a couple weeks later)... but I also know there are folks where who might have the same issue I did but got rebuffed by their dealers not to get it fixed :). Make noise! Complain! Get your things fixed for free while you can :).
I'll attach the (heavily redacted) actual invoice but will summarize (Jay-I not AI):
- Verified customer concern is only present when AC is on, no codes found
- Ran OASIS for TSB/SSM found none
- Noise is loudest from the climate controll A/C compressor
- Installed AC Gauges and verified AC charge level
- AC Compressor has internal fault; recommend replacing compressor and flushing system.
[ I assume this is when I got the call and had to wait for parts]
- Recovered all refrigerant from the climate control AC system
- Removed AC compressor
- Removed Front Bumper & Manifold & tube assembly to access AC evaporator and condensor for flushing
- Flushed for 15 minutes each followed by 30 minutes of purging to remove all solvent from heat exchangers. Total time to flush AC heat exchangers 2.0.
- Installed new AC Compressor
- Installed new TXV
- Installed new Receiver Dryer
- Replaced all AC gaskets and seals per WSM
- Pulled vacuum on AC system for 40 minutes and charged system with .610KG of R1234YF.
- Tested verified AC blows cold, no abnormal noise.
The parts listed are (I'll let you look at the doc if you want the part numbers:
- Compressor ASY
- Valve ASY - EV
- Dehydrator ASY
- Kit - Air COND
- Kit
- Kit
- O Ring
- Kit - Flushing
Ford F-150 Lightning Loud whirring sound, drivers side: AC Compr Fixed #20 signal-2026-07-25-08-06-09-762
Farmford42
WA
69 Bronco
Farmer
You did get this under the emission warranty or standard warranty? Mine just got diagnosed and looks like a $3500 fix. But they said its part of the battery cooling so that should be emissions?
@TaxmanHog is the Air Conditioning compressor tied to the high voltage battery cooling?
