I have innumerable screen shots of my Lightning data. Don’t know if I have any right at 90% and 10%.Does anyone have an extended range Lighting, have an OBD scanner and if so, would you be willing to scan the truck and post the battery voltage at 10% and 90%. The scanners are cheap on Amazon and just plug in. I want to compare battery voltages.
Let me know if there are some other points you want.Thanks. That will probably do. I can make a graph with it.
https://www.f150lightningforum.com/...-state-of-charge-percentage.19486/post-390486Does anyone have an extended range Lighting, have an OBD scanner and if so, would you be willing to scan the truck and post the battery voltage at 10% and 90%. The scanners are cheap on Amazon and just plug in. I want to compare battery voltages.
Yes, please. The more data the betterhttps://www.f150lightningforum.com/...-state-of-charge-percentage.19486/post-390486
I can probably dig up a graph that covers thecwhole span.
