OBD2 car scanner
MikeH
Toronto
eTransit, VW truck, VW ID4
HVAC
Does anyone have an extended range Lighting, have an OBD scanner and if so, would you be willing to scan the truck and post the battery voltage at 10% and 90%. The scanners are cheap on Amazon and just plug in. I want to compare battery voltages.
Kansan
Wayne
2024 Flash
Civil Engineer
I have innumerable screen shots of my Lightning data. Don’t know if I have any right at 90% and 10%.
Ford F-150 Lightning OBD2 car scanner IMG_9153
Ford F-150 Lightning OBD2 car scanner IMG_9149
Ford F-150 Lightning OBD2 car scanner IMG_8872
Ford F-150 Lightning OBD2 car scanner IMG_8963
Ford F-150 Lightning OBD2 car scanner IMG_9179
t
MikeH
Toronto
HVAC
t
Thanks. That will probably do. I can make a graph with it.
Kansan
Wayne
2024 Flash
Civil Engineer
Let me know if there are some other points you want.
Ford F-150 Lightning OBD2 car scanner IMG_9915
Ford F-150 Lightning OBD2 car scanner IMG_9962
mr.Magoo
2022 Lariat ER, AMB
mr.Magoo
2022 Lariat ER, AMB
Ford F-150 Lightning OBD2 car scanner 1748792830915-ns
It's the best I could find right now, but I was planningon driving it below 10% and charging to 100% sometime next week, so I'll post the results of that.
Attached is also the raw data / csv file.
