Disable Passenger Seatbelt Monitor System
Ajzride
Alan
Houston
Eng
Starting a new thread forking off from the Forscan thread. I'm looking to eliminate the seatbelt monitoring system. This is the system that gives you a popup on the gauge cluster when someone in the backseat unbuckles their seatbelt. I drop off kids 3-4 times per day, and this pop up is stupid because it isn't paired with a weight sensor to determine if someone is actually in the seat, and it never goes away until you click OK, it will cover your gauge cluster for miles and hours if you leave it there. Someone in the forscan forum stated this could be turned off in settings, but I've been unable to find it. All of my screens are pictured below.
This is the pop up to eliminate:
Ford F-150 Lightning Disable Passenger Seatbelt Monitor System 6488A4EC-7DB7-4D49-86BB-73376CD1191F
here are all my settings. If I’m overlooking the toggle for this please point it out.
Ford F-150 Lightning Disable Passenger Seatbelt Monitor System D1C463CA-8EF6-459A-8F0B-CC9E4EEC2C73
Ford F-150 Lightning Disable Passenger Seatbelt Monitor System D1B916B8-3DBE-4767-8262-2426EACAF8F2
Ford F-150 Lightning Disable Passenger Seatbelt Monitor System E3FA00BC-F35E-4E8E-8E90-9CBCD9B5A00B
Ford F-150 Lightning Disable Passenger Seatbelt Monitor System B7A08EAA-8569-4A26-B350-AFC74FCAC9E6
Ford F-150 Lightning Disable Passenger Seatbelt Monitor System 781B12B6-D5F9-4801-B001-0CA4FF0184FF
Ford F-150 Lightning Disable Passenger Seatbelt Monitor System 27096B68-C7FE-4949-B5D3-D3D605B6D253
Ford F-150 Lightning Disable Passenger Seatbelt Monitor System 7CDFEF96-B9B5-442E-BCCE-7D7F0B638E00
Ford F-150 Lightning Disable Passenger Seatbelt Monitor System 0D139AA4-38AC-48A1-9693-F8480E68F6CC
Ford F-150 Lightning Disable Passenger Seatbelt Monitor System 93EC36AB-56FF-40CD-ABDD-2E90B4315176
Ford F-150 Lightning Disable Passenger Seatbelt Monitor System 55DF830F-2AF3-48A5-8B80-837BBFD0AC18
Ford F-150 Lightning Disable Passenger Seatbelt Monitor System 1D19CEC6-0345-4822-927A-E66F9F20B908
Ford F-150 Lightning Disable Passenger Seatbelt Monitor System 31565609-2B98-4510-BF96-2E960508F36C
apMechorse
Steve
Fargo, North Dakota
'21 Ford Lariat 5.0L FX4; '14 Chevy Spark LS
Aircraft Maintenance Manager
It's not exactly a setting, but you don't need ForScan to do it:
Deactivating the Ford F-150’s Belt-Minder™ Seatbelt Alarm Feature
This procedure walks through how to disable the seatbelt alarm on the Ford F-150. Please note that the driver and front passenger warnings switch on and off independently. In order to disable the seatbelt alarm for both, you will need to follow this procedure twice. Before Getting Started: Make sure that (1) the parking brake is set, (2) the transmission is in park, (3) the ignition is off, and (4) the driver and front passenger seatbelts are unbuckled.
  1. Without starting the engine, switch the ignition ON.
  2. Wait until the seatbelt warning light switches off (this will take about one minute).
    Wait an additional 5 seconds before proceeding to Step 3.
  3. Choose which seating position you would like to switch off. Buckle then unbuckle the seatbelt 3x, ending in the unbuckled state.
    Wait for the seatbelt warning light to switch on before proceeding to Step 4.
  4. Buckle then unbuckle the seatbelt one more time. The seatbelt warning light should flash to confirm that the operation was successful.
How Do I Re-Enable My Belt-Minder™ Seatbelt Alarm?
Once the Belt-Minder™ seatbelt alarm is disabled, you will be able to re-enable the feature by repeating the exact same procedure outlined above. Just as it is with disabling the feature, you will have to re-enable the driver and front passenger seatbelt alarms separately.
Ajzride
Ajzride
Alan
Houston
Eng
AMechorse
I don't think this is the same thing. I've used this to turn off the chime on the front seats, but I'm not sure it will work on the back seats. I will test this at lunch and report back.
Thanks for the input.
Ajzride
Ajzride
Alan
Houston
Eng
No luck using the belt-minder disable on the rear seats. I'm 99% positive it's a separate system. I did try unplugging the sensor from the bottom of the latch, and that resulted in a belt monitor error: service required message. A paperclip jumping it didn't help either. I'll have to go out with a meter tonight and measure the resistance across the pins and see if I have a resistor I can jam in the connector to disable the system.
Geo
Geo
2021 F-150, 4x4, Lariat 501A pk. 5.0 V-8, Max Tow.
Have you tried a seat belt extender ? I have these in my wife’s Subaru. We use them from the mail box to the house, 1/4 mile. They stay in all the time. Work great and they will fit my f-150. But I can’t talk the wife into riding in the back seat to try them. I’ll get one of the grand kids tomorrow, and give it a try.
Ajzride
Ajzride
Alan
Houston
Eng
Seatbelt extenders do work... but they are so big they dig into the kids side. I'm not overly large (6', 175lb) and they bothered me a bit. My halfling kids are only 4' and 70 lb, they can't cope with them. I think a resistor will work once I measure the open and closed resistance.
Reactions: Geo
Ajzride
Ajzride
Alan
Houston
Eng
I measured the resistance on the latch side of the pins as 653K ohm. However a 650K resistor still resulted in an error screen. I checked the signal from the BCM and it was pulsing, so it looks like it might be some form of ICP or serial link between the two. Crazy complicated for a contact sensor. Maybe it’s time to head back to Forscan.
