Radar Detector With False Laser Warning
JerseyGlock
Jimmy
New Jersey
2021 Lariat Powerboost
Hello,
Any 21 F150 owners with radar detector (front / rear laser feature) having false laser warnings? Issue may be isolated to 21 f150 with eye tracking sensors on dash. I have a Passport Escort 9500i that laser warning just keep going off every couple of minutes. Called Passport, provided options on my f150 and was told warnings are eye tracking sensors related. Not much they can do unless I disable laser feature on detector.
AutonomousHybridF150
Kristopher
Pensacola Fl
2021 F150 Powerboost
Adjuster
I can confirm this is correct.
You have to disable laser on radar detectors that aren’t new enough to filter that later spectrum. Ive had the escort 9500xi for 5+ years and have used it in a 2009 F150 and 2013 SHO with no issue for a long time.
It took me 5,000 miles of driving my PB with the lane centering and blue cruise prep to figure out it was something my truck was emitting and that was reflecting off large signs and the back 18 wheeler trailers.
I haven’t looked it up yet, but I’m sure they can filter out FCC locked spectrums used by the autonomous vehicles and those features are likely built into escorts new 600.00 dollar radar detector.
Kristopher
Pensacola Fl
Adjuster
Oh look. It’s basically the #2 feature of the new $750.00 detector by escort.
AI Filtering - I need this in my life
Ford F-150 Lightning Radar Detector With False Laser Warning 8DE05AB3-0CF9-4411-BA92-5E7CF0D967F4
JerseyGlock
Jimmy
New Jersey
I am not turning off laser feature on Passport, I'll turn the volume to very low and deal with it. :(
UGADawg96
JAX, FL
302A 157 PB
This is why I stopped running my old Escort Passport 8500 X50 a few years ago and stuck with Waze. Every Walgreens door and other cars on the road would set it off.
JerseyGlock
Jimmy
New Jersey
That's nothing new, even happened with newer models too. This is why they create filter feature.
7cbreeze
Cass
Roseville CA
2015 Lincoln mkz , Sold 2011 King Ranch F350 ,6.7
Retired Mechanical Engineer
My Valentine 1 gen 2 also is working flawlessly
jamill
Jarred
Carlsbad, NM
2021 Ford F-150 Lariat & 2020 GMC Acadia SLT
Pipeline Operator
I have a Cobra SPX 7700 that I've had a few years. My truck doesn't have the laser eye tracking. However, any GM SUV (Tahoe, Yukon, Escalade, Acadia, Traverse, etc..) set it off for what I'm assuming is the blind spot monitoring. I get the occasional false alert, but it's actually been a pretty good unit.
Icecoldak
Alaska
2019 F-150 Limited
LASER on a RD is Useless --if you hear it go off you are toast anyway!!!! Get real laser jammers if you are in an area that has laser!! I can recommend ALP!!
cool rod
Rod
Central Florida
2021 F-150 Powerboost Platinum, 2013 Mustang
I'm experiencing the false Laser alerts on my Escort Passport 9500i which is about 8 years old. It goes off about every couple of minutes or so even though I've disabled the Laser detection feature. Changing its position using a beanbag mount seems to fix the problem, but I might just get a new detector if I can't find a good spot.
I have the Blue Cruise option in my Platinum, does the eye tracking work all the time or just when Blue Cruise is in use? I haven't received the software OTA update yet so I don't know if it's on or not.
Something reflecting off signs is an interesting idea, my Laser alert goes off when I'm in front of my metal garage door for sure. I'll watch to see if other things might be reflecting it, but I know it goes off when there's nothing in front of me on the road too.
I've been looking at the Uniden R7 detector, it's expensive but what the heck it's Christmas!
