"Stop safely now", 12V battery loosing charge, and rodent damage
htobin
Howard
Ovalo TX
F150 Lightning 2023 Lariat
Don’t be too sure, it’s not always that obvious. They can get in the cut and damage the wires farther down where you can’t see it.
woodsman
Stephen
decorah, iowa
2023 Lightning
Semi driver
Well, I have had my share of rodent damage. Chipmunks are bad, that is why I have cats. They chewed the cap off the radiator overflow, that is an extremely hard plastic. I had heard that some wire harness companies used a lubricant to pull wires that was soy based. The picture of the cut jacket does not look like rodents, they don't chew in a straight line. Look how straight the three ribs on the top left are, and how are the two on the top right bit off? Wrong bevel.
