"Technical Service Information" TSB? list - no #s, from Ford.com Support Service-Information
GoodSam
Good
occupying space
Not recalls, about 85! items so far, some obviously would not apply to the Lightning (emissions!, 8 inch screen, etc). Not sure how ordered. Why was not the TSB number provided? Is there a way to get such a list with #s?
230914 Technical Service Information, so far, for 2022 Ford F-150
https://www.ford.com/support/service-information/ using VIN or Model:
2021-2023 F-150, 2022-2023 Expedition - Pop Noise And/Or Static In Speakers At Start Up
Various Vehicles - Diagnostic Trouble Codes (DTCs) U2100 And/Or U3002 Stored InCCM, SODL, SODR, SODCMC, And/Or SODCMD
2021-2023 F-150 - Illuminated Airbag Light With DTCs U3000:54 And/Or U3000:41 Stored In The OCSM And/Or B00A0:09, B00A0:63, B00A0:64 And/Or B00A0:68 In The RCM
2021-2023 F-150 - Modules On HS2, HS3, HS4, MS CAN Networks Do Not Respond To FDRS
2017-2023 Various Vehicles - Telematics Control Unit (TCU) – FordPass/Lincoln Way Feature Unavailable Message
2021-2023 F-150 - Inoperative Windshield Wiper Motor With DTCs B130F:12, B130F:14, And/Or B1131:02
2017-2023 F-Super Duty/F-150 - With Trailer Tow Mirrors - Various Exterior RearView Mirror Functional Concerns
2022-2023 F-150 Lightning - Inoperative Cabin Preconditioning - Built On Or Before 13-Mar-2023
2022-2023 F-150 Lightning - This Trip Mileage Not Resetting After A Key Cycle
2021-2023 Various Vehicles - High Voltage Battery Stops Charging With Illuminated MIL And DTC P2C94 Stored In The SOBDM
2021-2023 F-150 Equipped With DCACA Inverter (Minor Feature Code HUKAK) - Illuminated TPMS Indicator With DTC B124D Stored In Body Control Module (BCM)
2021-2023 Various Ford And Lincoln Vehicles - Driver Monitoring Camera BlockageMessage And/Or Diagnostic Trouble Codes (DTCs) B115E:97, B15E1:97, B15E2:97
2022-2023 F-150 Lightning - Illuminated Malfunction Indicator Lamp (MIL) With Diagnostic Trouble Code P0A3C:94 In The SOBDMB And/Or SOBDMC
2022 F-150 - Navigation And Sirius Inoperative After SYNC (APIM) Programming OrReplacement
2021-2023 F-150 - Active Air Dam Diagnostic Trouble Code (DTC) C0604:00 Stored In The PCM
2021-2023 F-150 - OCS Component Replacement
2021-2023 F-150 - Inoperative Camera With DTCs C1001:01, B115E:15 And/Or B115E:31
TSB 22-2428 Missing Labor Operation Update
2022-2023 F-150 Lightning - Active Air Dam System Fault See Manual Warning Message In IPC
2021-2023 F-150 - Various Driver Assistance System Warning Messages - DTCs C1001:31, U3000:89, And/Or U3000:49 Stored In The IPMA
2021-2023 Mustang Mach-E, 2022-2023 F-150 Lightning - Exterior Charge Status Indicator Not Illuminating Blue Charging Segments After An OTA Update
2021-2023 - Various Vehicles - Trailer Lamp Fault With Various DTCs
2022 F-150 - One Or Both Headlamps Inoperative After A Performing A Body Control Module (BCM) Update With Or Without DTCs B14E5:08 and/or B14E7:08
2021-2022 F-150 Equipped With Light Duty Electric Park Brake Caliper - Squeal Noise From Rear Brakes When Applied At Low or High Speed
2021-2023 F-150/Mustang Mach-E/Edge - Android Auto Unable To Wirelessly ConnectAnd/Or Android Phones Rebooting When Connected To The Vehicle Via USB
2021-2023 F-150/Mustang Mach-E, 2023 Expedition/Navigator - BlueCruise/ActiveGlide - Hands-Free Driving Mode No Longer Available
2022-2023 F-150 Lightning - Illuminated MIL With DTCs U3012, P062F, And/Or PA07F In The BECM, And/Or P0887 In The SOBDMC Or SOBDMB
2000-2024 Various Vehicles - Errors Caused By Swapping Modules From Like Vehicles Or Ordering Modules Using Another VIN
2021-2023 F-150 - Equipped With 8 Inch IPC Screen And SYNC™ Without Navigation - Compass Direction Indication Stuck Or Not Updating Correctly In IPC
2021-2023 F-150, 2021-2023 F-Super Duty, 2021-2023 Ranger - Bed Feature And/Or Tailgate Malfunction After Spray-In-Bedliner Installation
Various Vehicles - Keyless Entry Keypad And Master Code Retrieval
2021-2022 F-150 - Diagnostic Trouble Code (DTC) U3000:54 Stored In The Vehicle Dynamics Module (VDM) And Will Not Clear
2022-2023 F-150 - Single Exhaust - Wiring Chafe To Rear Axle - Built On Or Before 17-Feb-2023
2021-2022 Bronco Sport And 2021-2023 F150 - Cornering Lamps Feature Operation
2022-2023 F-150 Lightning - Movement In Lane With BlueCruise Feature And/Or Lane Centering Active
2021-2022 F-150 - May Not Communicate With Emissions Testing Equipment
2021-2022 Various Vehicles - SYNC 4 - Procedure Unsuccessful - GetConfigDataFromGIVIS Error Message
2021-2023 Mustang Mach-E, 2022-2023 e-Transit/F-150 Lightning - Level 3 Charging, Illuminated Charger Service Required Indicator In The IPC And/Or Multiple DTCs
2021-2023 F-150/Transit, 2022-2023 F-150 Lightning - Discontinued Features In FordPass
2021-2023 Various Vehicles - Tire Sidewall Wavy/Indentation Appearance
2021-2023 F-150 - Equipped With Blind Spot Information System (BLIS) - Blind Spot Monitoring Inoperative
2021-2022 F-150 - Headlamps Turn On By Themselves When Vehicle Is Off, DTC B1533
2021-2022 F-150 - False Alarm Activation With A Trailer Connected And/Or DTC U0143:87 Stored In The Trailer Module (TRM) After TSB 22-2122
2021-2023 F-150 - Side Door And/Or Hood Ajar Warning Message In The IPC With OrWithout DTCs P166B, B1175, B1176, B11C1 And/Or B11C0
2021-2023 Mustang Mach-E/F-150/Edge/Nautilus, 2022-2023 Expedition/Navigator/Bronco, 2023 Escape/Transit/Corsair - DTC U3000:57 - Unable To Clear
2021-2022 F-150 - Center Display Screen Button Overlap After An OTA
2018-2023 F-150/Expedition/Navigator/Transit/Explorer/Aviator - Illuminated Malfunction Indicator Lamp With DTCs P0627, P025A, P025B, P00C6, P008A And/Or U0109
Various 2015-2023 Vehicles - Inoperative Or Clicking Sound From Power Folding Exterior Mirrors
2022 F-150 Lightning - With Red Triangle Illuminated Or Charge Status Indicator(CSI) Blinking Red With DTCs P27B4, P0A7F And/Or P0CF7
2015-2023 F-150, 2017-2022 F-Super Duty, And 2019-2023 Ranger - Dust Ingress Into The Cabin
Various Vehicles - Noise When Brakes Are Applied
2020-2022 Various Vehicles - Wireless Accessory Charger Inoperative/Poor Performance With Magsafe Charging iPhones
2021-2023 F-150 - Lack Of Steering Assist On Start Up With Steering Assist Fault Message In The IPC With DTC U3001:89 And U3000:96 In The PSCM
2022-2023 F-150 Lightning - Ting, Pop Or Clicking Noise From The Front Or Rear Wheel Hub When Accelerating Or Applying Brakes (Torque Reversals)
2021-2022 F-150 3.5L PowerBoost, 2022 F-150 Lightning - Illuminated ABS Indicator, Stability-Traction Control Indicator And DTC C1013:09
2015-2022 F-150, 2017-2022 F-Super Duty - Tailgate Step Assemblies - Trim CoverReplacement
2021-2022 F-150 - DTC B162F:13 Stored In The BCMC
2021-2022 F-150 - Built With B&O Branded Audio System – Reduced Rear Speaker Audio Volume
2022 F-150 Lightning - Phone-As-A-Key Equipped - U3000:49 DTC Stored In Remote Function Actuator (RFA) Module
2022 F-150 Lightning - Without Remote Park Assist - Power Hood (Frunk) ExteriorButtons Inhibited During Two Stage Lock
2021-2022 Mustang Mach-E, 2022 F-150 Lightning/e-Transit - P1A10 And U3012 After Low Voltage Service Disconnect
2016-2022 Various Ford And Lincoln Vehicles - SYNC 3 and SYNC 4 - Issues With Vehicle In Transport Mode
2021-2022 F-150/F-Super Duty Vehicles - Rear Window Glass Sliding Panel RattlesWhen Open And Music Is Playing - B And O® Audio System
Adding/Removing Features Using Programmable Parameters Due To Vehicle Modifications
2021-2022 F-150 - Tailgate Snap, Click, And/Or Pop Noise When Closing
2021-2022 F-150 - 400 Watt DC/AC Inverter System Inoperative With B1330:9A In The BCM
2021-2022 Mustang Mach-E, 2022 F-150 Lightning/E-Transit - Unable To Achieve 100 Percent State Of Charge After HV Battery Module Replacement
2021-2022 Mustang Mach-E/2022 Expedition/F-150 Lightning - Blank/Inoperative Information And Entertainment Screen - DTC B108E:01
2015-2022 F-150, 2017-2022 F-Super Duty And 2018-2022 Expedition/Navigator - Poor A/C Performance
Various 2017-2022 Ford And Lincoln Vehicles - Missing Authorization, Command And Control Or Phone-As-A-Key Buttons In FordPass Or LincolnWay App
2021-2022 F-150 - Door Will Not Open From The Exterior Handle
2013-2023 Various Vehicles - 12 Volt Battery Drain When Using Third Party PhoneApplications- Modems Activated Through FordPass Or LincolnWay
2021-2022 F-150 - 2.7L EcoBoost - Check Charging System Message Displayed In The IPC
2021-2022 Mustang Mach-E/F-150/Edge/Nautilus - SYNC Gen 4 - Loss Of Bluetooth Pairing After A Key Cycle
2017-2022 Various Ford And Lincoln Vehicles - Front Seat Track Motors Serviceable Separately
2021-2022 Mustang Mach-E/F-150 - Reverse Brake Assist Unavailable After Module Programming
2013-2022 Various Vehicles - Seat Pan Looseness, Lateral Movement, Or Clunk/Thump Noise On Turns
2018-2022 F-150/F-Super Duty - Tailgate Step Assemblies - Step Binds/Will Not Open Or Opens/Pops Up While Driving
2022 F150 - A/C Leak Detection Diagnostics Updated
2022 F-150 - Vehicles Not Equipped With A Trailer Brake Control Module - ABS Module DTC U0137
2020-2022 F-Super Duty/Explorer/Aviator, 2021-2022 F-150 - Various Warning Messages And/Or DTCs - IPMA Programming
2021-2022 F-150/Bronco – Certain SYNC 4 Equipped Vehicles Require Android Auto or Apple CarPlay For Voice Interactions
GoodSam
GoodSam
Good
occupying space
Well then, how about using the NHTSA site to see Ford's Manuafacturer Communications to look for TSB's (SSM = Special Service Message)? Found these:
42 Manufacturer Comms (as of 7-27-2023)
for 2022 FORD F-150 (Super Crew) Lightning BEV
https://www.nhtsa.gov
July 27, 2023- TSB 23-2239- inoperative cabin preconditioning event.
July 20, 2023-
SSM 51805- This Trip mileage not resetting
July 3, 2023-
SSM 51761- P0A3C:94
June 23, 2023-
22-PU0930RBA-CHM- 22-PU0930-RBA-CHM, 6 items: Frunk, 12V, etc
June 14, 2023-
OTA23PU0327F150B- 23-PU0327-DSP-AMP, static noise
June 8, 2023-
SAN-Vol1 I1- Service Awareness Newsletter
June 1, 2023- TSB 23-2169- inoperative cabin preconditioning event
May 29, 2023- TSB 23-2126- Active Air Dam System Fault
May 29, 2023- TSB 23-2125- lower than expected vehicle range
May 24, 2023- 22-PU0930-RBACHM- 22-PU0930-RBA-CHM
May 19, 2023- 23-PU0105-DC-CHG- 23-PU0105-DC-CHG2- DC Fast Charging
May 9, 2023- SSM 51618 charge status indicator not illuminating
April 20, 2023- SSM 51567- Midtronics DCA8000P battery tester is unable to test
April 18, 2023- SSM 51560- This Trip mileage not resetting
April 7, 2023- SSM 51545- (DTCs) U3012, P062F, and/or P0A7F- loose 12 volt
April 7,2023- 23-PU0306-BCF-DET
- erroneous "Air Dam Fault", preconditioning, 12V battery drain etc
April 5, 2023- 23B09- Battery Coolant Tube Assembly
March 29, 2023- OTASU4P2F150BEV- Software Update 4 P2- Prevents intermittent loss of connectivity
March 28, 2023- PU0105-DC-CHG2- 23-PU0105-DC-CHG2- DC fast charge
March 15, 2023- 22-PU0930-RBACHM- 22-PU0930-RBA-CHM- Improved key off load
March 9, 2023- TSB 23-2073- Lane Centering
March 2, 2023- SSM 51408- This Trip mileage not resetting
March 2, 2023- TSB 23-2014- inoperative level 3 charging
February 23, 2023- SSM 51379- features (if equipped) in the FordPass app
February 1, 2023- 23H01- High Voltage Battery Module Replacement
January 30, 2023- Active Air Dam System Fault
December 14, 2022- 22OTA SU4P1F150- Software Update 4 P1- battery charge slider- bidirection power transfer
November 30, 2022- 22OTA22PU1110SNC- 22-PU1110-SNC-RS- 1-Pedal-Drive pop-up
November 29, 2022- TSB 22-2395- ting, pop or clicking noise
November 23, 2022- TSB 22-2448- stability-traction control indicator & DTC) C1013:09
November 14, 2022- 22OTAPU2210MILDT- PU-22-10-MIL-DTE- park brake, motor temp, false DTC, 12V battery drain
October 19, 2022- SSM 51135- Phone-as-a-Key
October 13, 2022- TSB 22-2385- inoperative power hood (frunk)
October 6, 2022- 22P08 S2- BlueCruise
September 29, 2022- OTASU3P3F-150BEV- Software Update 3 Part 3- frunk ajar, 12V battery,etc
September 23, 2022- OTA22PU0929BLMUP- 22-PU0929-BLM-UP- Phone-as-a-key (PaaK)
September 22, 2022- SSM 51095- (DTCs) P1A10- SOBDM- U3012- BECM- LVSD not being fully seated
September 22, 2022- SSM 51094- (DTCs) U3012, P062F- BECM- loose 12 volt
September 20, 2022- TSB 22-2355- inoperative level 3 charging-
August 4, 2022- OTA SU3 P2 F150- Software Update 3 Part 2 Bi-directional power fix
July 31, 2022- OTASU3P1F150BEV- Software Update 3 Part 1- incorrect FordPass charge, android auto black, scale fix, etc.
July 6, 2022- SSM 50923-
EVgo Fat Boy charging
Fuller listing of these in a Word doc file attached below, but there are various size "Manuafacturer's Communications" PDF docs attached for each one for further details. Might be able to click on the Word doc "MC-102XXXXX-0001.pdf"s and the link might work?
GoodSam
GoodSam
Good
occupying space
"posted in OASIS with a date of 15 Sep" 2023
https://www.f150lightningforum.com/...-then-alien-clicking-static.12315/post-336553
SSM 51926 2021-2023 F-150, 2022-2023 Expedition - Pop Noise And/Or Static In Speakers At Start Up
Some 2021-2023 F-150, 2022-2023 Expedition vehicles equipped with 10 channel audio digital signal processing (DSP) module may exhibit a pop noise and/or static in the speakers at start up that cannot be turned down or off using the audio system controls. To confirm a vehicle is built with a 10 channel DSP module, verify the minor feature code, F-150
(IDBBQ)/Expedition (IDBAP or IDBBR), by reviewing the build information by double-clicking the vehicle identification
number (VIN) in the upper left corner in the Professional Technician System (PTS) website. To correct the condition,
reprogram the DSP module to the latest software level using the Ford Diagnosis and Repair System (FDRS) diagnostic
scan tool. For claiming, use causal part 18B849 and applicable labor operations in Section 10 of the Service Labor Time
Standards (SLTS) Manual.
A few more acronyms that need to be defined in that paragraph. Maybe add to the list at the Mach-E forum:
https://www.macheforum.com/site/threads/acronyms-tlas-and-initialisms.6365/page-2
Here is an earlier one about the same issue:
SSM 51663 2021-2023 F-150/Expedition - Pop Noise And/Or Static In Speakers At Start Up
2021-2023 F-150/Expedition may exhibit a pop noise and/or static in the speakers at start up that cannot be turned down or off using the audio system controls. To correct the condition, reprogram the audio digital signal processing module (DSP) to the latest software level using the Ford Diagnosis and Repair System (FDRS) diagnostic scan tool. For claiming, use causal part 18B849 and applicable labor operations in Section 10 of the Service Labor Time Standards (SLTS) Manual.
GoodSam
GoodSam
Good
occupying space
GoodSam
GoodSam
Good
occupying space
