Tonneau Cover Range Improvement numbers
FloridaMan655321
Banned
Banned
Banned
1973 F100, 2024 Flash
I started covering my truck beds for one single reason, to keep asshats from using my truck as their garbage can. Too fking lazy to keep holding that empty until they get to an actual trashcan, no they just drop it in the bed. Infuriates me would be describing it lightly.
This is such a strange thing that happens. I've literally never been holding an empty container and saw a bed truck and thought "let me throw it in there"
FloridaMan655321
Banned
Banned
Banned
This subject is so tired that I remember reading a study back in the late 90s that tested tailgate up, tailgate down (because that was a thing back then), and then those weird tailgates that had holes in them and looked like snowmobile fencing (except not orange). It was stated even back then that the air kept in the bed with the tailgate up created pressure to keep the airflow over the whole vehicle. So even back in the 90s we knew putting your tailgate down or having those air tailgate things were useless. Still applies with a tonneau cover.
ZeusDriver
East Coast, USA
2022 Lightning
Putting the truck in a wind tunnel and seeing what happens with and without the tonneau cover seems like the way to answer the question - but will it be enough for us to even notice with combined highway and city driving? I am doubious.
The SEMA tests were performed in a good wind tunnel, and I am inclined to believe their findings (of about a 5% improvement in Cd with a tonneau cover, and a 1% degradation with the tailgate down.) The latter is not enough to show up (in consumption) in even a well-controlled, correctly-instrumented track test on an oval track. The former could show up in a very good track test, (as a reduction of circa 2% in consumption) but I have not seen such a test yet.
My Zing, from 2010 or so, achieved slightly lower drag than the Aptera (of that time) I thought at the time. (We were both in the same contest, until I pulled out, in a huff, at rule changes that made it impossible to win with anything other than a pure electric car.) The Aptera Cd was probably lower, but my frontal area was substantially less, because the seating was tandem instead of side-by-side. (My weight was less than half of the Aptera's.) I think my Cd was on the order of .16 or .18. At the time, the Aptera had its suspension members hanging out in the breeze, which is problematic for good aero. (Three wheels are problematic for aero too, a minor problem we both had.)
Back then, reasonable people considered wells-to-wheels as being the valid measurement for "goodness" in high efficiency vehicles. The calculations are complicated, for sure, but only by going through with them can you determine if a Tesla or a Prius is the more benign vehicle in West Virginia (the Prius wins) vs New Hampshire (the Tesla wins). There were teams in the X Prize who had developed engines from scratch (burning biodiesel, ethanol, etc), which, after the rules went to plug-to-wheels, could not possibly win. Sad. Fabulous efforts. As I remember it, the rules shifted when Musk ended up on the advisory board for the X Prizes. I could be full of it, however. Many of the contestants were active in developing the rules, and then suddenly they went in a new direction.
Adding to the Irony: The GM EV1 could achieve 100mpge (which is what the metric went to instead of wells-to-wheel). The X Prize was about achieving a 100 mpg vehicle that could be marketed in significant numbers. GM had already done that, (a decade it turns out, if you view electricity as showing up at the outlet without any environmental consequence.
I remember thinking at the time: many people worry about the handful of watts difference between incandescent bulbs and LED's, but consider the hundreds of thousands of watts consumed by an EV as being benign.
Hrumfff.
But back to the point of the thread: No, you cannot measure the effect of either a tonneau cover or an active front air dam on the road. But both have an affect: the cover about 5% in Cd, the dam about 4% in Cd. Combined, maybe as much as 2% or 3% in consumption. Given that my consumptions varies from day to day by about an order of magnitude greater than that (in other words by 20% or 30% ) I am not able to say that it has a great affect on me personally, other than to say that over time, my $100 tonneau cover pays for itself. Woo Hoo!!
And.... AND.... this is where we should get weepy, cuz we are saving the world: the combined effect of those two features reduces CO2 production by some very large number of tons, across the Ford fleet.
Reactions: chl
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
interesting.
I bought the bed cover so I had ONE PLACE I don't have to shovel snow anymore...:sneaky:
ZeusDriver
East Coast, USA
2022 Lightning
Fwiw I have done tuft testing and did not observe any airflow off the cab hitting before the tailgate.
You must not have had the tufts in the right places. Just put a pile of leaves in your bed and go for a drive. You will see vortices that lift the leaves out of the bed, and the leaves will help you see the vortices.
02Reaper
GA
2022 Lightning XLT ER
There was a thread on here a couple of years ago about the aerodynamics. Here is another video on aerodynamics.
Here is some more insight from Ford on wind tunnel testing on a f150. You can see that they still use the channel on the lightning front.
Here is some wind tunnel testing on an older model f150. Seems that Ford focuses a lot around the headlights and front quarter panel.
Reactions: chl
The tufts were across the entire back half of the cover.
Vortices are turbulent flow. There is of course air movement in the bed area. Tuft testing showed there was no smooth flow in the bed area, it showed that the airflow off the cab is not touching down in the bed area and that all air movement back there is turbulent.
Back to the point. At typical highway speeds the airflow is going to land behind the tailgate, not on a cover. There might be gains from a flat surface behind the tail gate, but not likely from in front of it.
Yes, that's why winglets on jet planes work, they reduce the votices between the top and bottom of the wing:
https://www.google.com/url?sa=i&sou...aw19s8y64bfmKhmFmoMToAEn&ust=1765049437565000
Pitbull2o08
Ohio
2011 F150 FX4 Ecoboost 2023 F150 Lightning Lariat
"So, the theory is this: a tonneau cover lowers the Cd (coefficient of drag) of a pickup truck. That is almost universally true, for reasons that are probably intuitively obvious. The tailgate is an obvious apparent wind catcher. Try to carry a sheet plywood with the flat side facing the wind on a gusty day, and you will appreciate aerodynamic drag."
This is false because, well, physics. The tailgate does trap air, creating a high pressure environment inside the bed. The increase in velocity of air over the truck drops the pressure above the high pressure system, a la venturi effect. although this isn't a perfect system and some swirling can occur, there is no outlet for the high pressure other than to stay high pressure and confined within the space of the bed. Generally, the fast moving air flows over the roof and over the box and creates turbulent flow behind the tailgate.
ZeusDriver
East Coast, USA
2022 Lightning
I assume you are just being belligerent for fun, but in fact, there is nothing in the paragraph you quoted that is false. And oddly, you go on to agree with my several points. Wierd.
The First Statement:
"So, the theory is this: a tonneau cover lowers the Cd (coefficient of drag) of a pickup truck."
That is entirely true and very well known by every aero guy or gal at all the manufacturers. Does the theory pan out in practice? That's another question. But the answer there is also well known, and Brad Richards of Ford (see the autoblog video) puts its well: "Tonneaeu covers are more efficient." He goes on to say that the tailgate top surface mimics the last 6 inches of a tonneau cover.
So the first statement 100% true. Anyone arguing otherwise, would have to know essentially nothing about the last 50 years of auto aerodynamics studies.
The Second Statement:
"That is almost universally true, for reasons that are probably intuitively obvious. " It is 100% true that the theory is universally recognized, by those with subject matter expertise. Granted, there are loads of people who know nothing about aerodymanics, but I think, in context, we can say that I am not treating their theories (whatever they may be) as a "theory". They are instead "hunches". For example, the hunch that lowering the tailgate would reduce drag is clearly not useful. The SEMA tests. long ago showed that not to be valid, as had tests elsewhere at manufacturer's wind tunnels decades ago.
So, again: 100% true.
The Third Statement:
"The tailgate is an obvious apparent wind catcher." No one but a fool would disagree with this, and even you agree: "The tailgate does trap air," you say.
100%, unambiguously, and simply true.
(The second part of your statement is not strictly true without further explanation, given that local velocities within the general bed bubble are actually substantially higher that the free stream velocity, and therefore of lower pressure. Bed blowing would help with your theory.
The fourth statement:
Even people with essentially no aerodynamic training or exposure to physics would agree with this statement, unless they have led very sheltered lives. I might have gone on to say "Hold the sheet at its trailing edge, and with an angle of attack of 10 degrees, and as it flips over on top of you, you may also gain an intuitive understanding of lift... and even aerodynamic center and moments" .
100% true and known to anyone who has given these issues any thought.
So, were you hallucinating, or perhaps responding to someone else's post?
Are you thinking the Brad Richards is a fraud? What do you think his motives for lying would be?
Reactions: chl
ZeusDriver
East Coast, USA
2022 Lightning
If you are saying that "useless" still applies to the use of a tonneau cover, then the subject is not tired -- you are proof that there are still people who have no understanding of the aero involved, but still pontificate about it online. Having spent a few years consulting with Ford, I can say that the people like Brad Richards (middle management) are generally straight shooters (and many of them are pretty smart). (C-level folks, maybe not so much). So what motive do you think he has for lying about the beneficial effects of a tonneau cover?
FloridaMan655321
Banned
Banned
Banned
My point is that people for decades keep thinking that because there is an empty bed in the back of a pickup truck, that the wind must perfectly go over the cab and blast right in the tailgate and impact MPG. I’m sure you could add a big wing on the back and it’s going to do something, but will it be noticeable?
I love tonneau covers and am actually in the process of buying one, but I understand that adding this will not be any noticeable MPG increase. This is more of a ‘do you need one for utility reasons’ question, and if you do, get one, if not, don’t think the price of one is going to offset the savings of energy.
Hrumfff.
Agreed.
I saw my electric bill go down noticeably when I switched to CFLs, and again to a small degree when I switched to LEDs from the CFLs.
The biggest drop was when I got a hybrid (heat pump) water heater - paid for itself in a little over a year in savings, not to mention the reduction in related CO2.
I expect there is some small benefit from a tonneau cover because of reduced drag. I probably won't really notice it because I do most of my driving at 25-35mph where weight/friction is the main drag so to speak (not literal drag) on efficiency, not aerodynamics.
Even so, preaching to the choir here, we are spending way less money per mile in the Lightning than a comparable ICE F-150, so rejoice and celebrate the Lightning.
There might ve some points in there if you weren't relying on grandstanding so much.
If you have to be that condescending to make a point your might be arguing from an emotional perspective rather than a logical one.
The simple fact of the matter is that on our trucks, trucks that are VERY sensitive to changes in efficiency, it has been reported over and over again that covers do NOT impact range. Now I have said my piece, but you seem to continue to treat them as singular objects when there are a large number of external factors that determine if a cover may or may not be effective.
But I say it again, if your argument relies so heavily on long winded missivs and demeaning comments you are not arguing from the perspective of logic, you are doing so from emotion.
Who was doing the reporting?
And what was their method of making that determination?
My point is some things that are merely seat of the pants conclusions when tested scientifically turn out to be wrong - that is what about 1/2 of Mythbusters is about.
But you cannot seriously be arguing with wind tunnel tests that show the opposite, are you? That show that a tonneau cover on a pickup truck reduces aerodynamic drag?
That's a controlled test with precise instruments, not an anecdotal observation based on imprecise data.
People used to think a cannon ball would fall faster than a pea, based on their intuition, their guts, a seat-of-the-pants conclusion, but Galileo showed that was wrong with a scientific experiment.
My yard may be flat, but the earth is round.
I can draw a circle with a compass for example, and think that I can measure the circumference with a tape measure, and measure the diameter with a ruler, and then know precisely what the ratio between them is. Alas, the ratio of the circumference to the diameter of a circle is an irrational number (pi) that has an infinite and non-repeating decimal pattern and it cannot be expressed as a simple fraction of two integers, even though I thought it could be.
Time is not absolute either, it changes based on gravity and speed.
Clocks run slower at sea level than in at high altitude because gravity is stronger at sea level.
And gravity is the curvature of space-time based on mass and energy.
The clock at sea level is deeper in the curve of space-time.
Not to pontificate too much but people can have their own opinions and they may and often do differ.
But we ought to accept scientifically obtained, precisely measured data even when it counters our preliminary opinion about something.
Unless we can find an error in the experiment, the equipment, the calculations, we ought to accept it as valid.
Us Lightning owners trucking down the road for thousands of miles at varying speeds and under varying conditions may not notice any difference between a tonneau covered and an uncovered bed on efficiency, but that is not a controlled experiment so no definitive conclusion should be drawn from it about aerodynamic quantitative effects.
