UTA's - Unexplained Truck Activities
Lytning
Georgia
I have experienced several UTA's ... Unexplained Truck Activities of unusual things that happen with my truck with no apparent logic associated with them. Shortly after delivery, I experienced the extremely loud audio system runaway event. Thankfully, that has not recurred. @Ford Motor Company never followed up on my complaint, so I have no explanation. I also received at least 6 OTA updates during short stops at the same Total Wine parking lot, but those (and almost all other) updates have stopped. I am still on BlueCruise 1.0.
The current UTA is occurring at a Urologist's office. (I almost named the thread UTI's). :facepalm: On at least 4 occasions, my truck doors will not lock or unlock by touching the sensor on the door handle when the truck is in this one Doctor's parking lot. I have to use the key fob to lock and unlock the doors. The door touch sensor works everywhere else, including other Doctors' offices. I have an Ohmmu 12 volt battery and SOC's are 90% to 100%.
Does anyone have a logical explanation for the door lock UTA?
EVpower
Steve
Northern California
2023 F-150 Lightning Lariat, Bronco II
Electrical Engineer
As an RF (radio Frequency) Systems guy, when I hear of a location specific fault, I tend to suspect an interference problem. Maybe a FOB battery aging?? Airport or broadcast transmitter nearby?
Steve
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
Maybe thinking of what the urologist is going to do causes stress and perspiration that prevents the sensor from working. :LOL:
Adventureboy
The unlock sensor is on the backside of the handle. I've noticed that with recent Ford App updates, these sensors don't work if my phone has been locked for a while. Unlocking the phone normally always fixes this but it could also simple be that my phone is out of my pocket by then. The lock button has always been flaky for me. The technique that works for me most of the time is to brush across it with my fingers rather than just touching it.
@EVpower has a valid point. If there is enough RF interference, it can affect various functions in different ways. Touch Lock/Unlock uses low-power NFC frequencies, while the key fob uses different frequencies that may not have as much local interference, or the key fob button simply has more broadcast power than NFC.
Adventureboy
I have a theory on this. If you power down the truck and then bump the volume up button on the wheel as you exit, the Sync system may have the volume up button state active as you exit the truck and Sync goes into standby in this state. Starting up the next time, may cause a runaway volume up event until one of the buttons are pressed or volume knob turned which may take a few seconds to activate on startup, and by then it is blasting away.
Hopefully, this hasn't happened again and Sync updates have fixed the potential sticky state.
Lytning
Lytning
Georgia
Steve
Good ideas. There are no visible antennas nearby, and it is not near an airport or broadcaster. I park away from the building under a large oak tree. Maybe an underground power feed to the building?
Electric Messiah
Davis
Massachusetts
F150 Lightning Lariat ER
Logic tells me patients will know Doc's successfully diagnosed plumbing issues when they get back to the parking lot and find lock/unlock working smoothly again!
I concur with the idea of RF interference with the key Fob.
If you look around the oak tree area you may spot a 5G antenna somewhere near by, but RF can bounce off things and be in unexpected places.
Offices these days have wifi that may reach the parking lot.
A low FOB battery is another possibility, if the rf signal from the key FOB is weak, then it is more subject to interference.
I always have trouble with touch handles and touch screens - not sure but I suspect it has to do with the conductivity or lack thereof and/or the charges present or not present on my fingers. It is very annoying when I am trying to use smart phones, check out screens, and sometimes the lightning dash screen too. That doesn't sound like your problem though since it is only in this one parking lot.
OTAs
Since it does not seem to be your LV battery preventing OTAs, I would just mention they don't come all that frequently to begin with, so it may be there are none that you are missing?
The last one I got was a Frunk update in September 16th 2025 or so.
There is a way to check for updates history on the Ford web site:
https://www.ford.com/support/software-update-release-notes-history/
But how does one know if there was one they missed?
Look under "recalls" - https://www.ford.com/support/recalls-details
However, I just tried and got this message:
"We are not able to retrieve recall information for the VIN you have entered."
LOL?
Of course check to see that you have automatic updates turned on in your truck or in FordPass.
One time my automatic update setting got turned off somehow - I swear I don't remember doing that, some computer gremlin probably did it?
There is also the question of the ATT cell network - variations in solar activity, etc. can cause problems with communications equipment. I live is an area with weak ATT signals already. I did get a message from the Virginia Mileage Choice program recently that said my OBD GPS device had not sent a signal recently and to check it was still working. I drove my truck up to the top of a nearby hill with a shopping center and bought some groceries, and the next day the data showed up on their web site.
These types of things were my biggest concern before I bought my Lightning - ghosts in the machine. Driving a computer with wheels is putting a lot of faith in computers and programmers, and my many years of experience with those gave me some trepidation.
There's always something...
Lytning
Lytning
Georgia
[/QUOTE]
It is likely RF interference of some origin. I will try a different parking spot next time. FOB battery is good. I sometimes have the same issue as you with capacitive touch screens. Slightly licking my finger usually gets it to work. I received the same message when checking for recalls.
Reactions: chl
[/QUOTE]
Yes spit or sweat adds some conductivity to the surface of the skin - and reduces resistivity as well, which is why it's easier to get electrocuted when you're wet.
I'd only do that at home for my tablet, not at a CVS or grocery store check-out screen though, lol.
Besides the strength of the signal from the FOB, there is also the question of receiving and decrypting the signal with the truck receiver and CPU.
I saw this about trouble-shooting when things aren't working correctly, one of top things is RF interference, and many of us here suggested that.
Troubleshooting Common Issues
Even though key fobs are designed to be durable and reliable, occasional issues can arise. Here are some common problems and how to fix them:
Signal Interference
If your key fob isn’t working from its usual distance, signal interference might be the cause. Try these steps:
  1. Remove Interferences: Keep the fob away from electronic devices and metal objects.
  2. Reposition the Fob: Change the position or angle of the key fob.
  3. Check the Car's Antenna: Ensure the car’s antenna is clean and unobstructed.
Physical Damage
Physical damage can affect the key fob's functionality. If it has been dropped or exposed to water:
  1. Inspect for Damage: Look for cracks or signs of water damage.
  2. Dry Out Moisture: If wet, remove the battery and let it dry completely before reassembling.
  3. Consider Replacement: Replace the fob if damage is severe.
Security Concerns
With advancements in technology, there’s a risk of signal hijacking. To protect against this:
  1. Use a Signal Blocking Pouch: Store your key fob in a Faraday pouch.
  2. Disable Keyless Entry: Turn off this feature if not needed.
  3. Stay Informed: Keep up-to-date with security recommendations for your vehicle.
Preventive Measures
  1. Regular Maintenance: Check your key fob periodically and replace the battery as needed.
  2. Safe Storage: Keep your key fob in a safe, dry place.
  3. Professional Checkups: Seek professional help for persistent issues.
If your key fob isn't working, the problem could extend beyond the device itself to the car's internal systems. Tools like automotive data loggers can help diagnose these deeper issues by analyzing data from your car's onboard network
https://www.autopi.io/blog/what-is-...by sending,, performance monitoring, and more.
good luck
