2004-2021 F150 17x8.5" fifteen52 Turbomac HD Wheel 0mm Offset
Stage3Motorsports
Arizona
2021 F150 STX CrewCab 4x4
In stock Fifteen52 wheels are now on sale BUY 3 get 1 FREE!!!
The Fifteen52 Turbomac HD wheel is in stock in Block Bronze, Asphalt Black, and Magnesium Grey.
(magnesium grey is not on the site so you will need to message me to purchase)
2004-2021 F150 & Raptor 17x8.5" fifteen52 Turbomac HD Asphalt Black Wheel 0mm Offset THDAB-178565-00
Ford F-150 Lightning 2004-2021 F150 17x8.5" fifteen52 Turbomac HD Wheel 0mm Offset -1d91-47dc-8a62-98d0add3cdde_1200x1500_crop_center
2004-2021 F150 17x8.5" fifteen52 Turbomac HD Block Bronze Wheel 0mm Offset THDBB-178565-00
Ford F-150 Lightning 2004-2021 F150 17x8.5" fifteen52 Turbomac HD Wheel 0mm Offset 6lug-bronze-black-17x85-1000_1200x1500_crop_center
Ford F-150 Lightning 2004-2021 F150 17x8.5" fifteen52 Turbomac HD Wheel 0mm Offset -e680-47fe-b021-9a4519c92785_1200x1500_crop_center
Highlights:
  • Awesome off-road styling
  • Influenced by Ken Block
  • ****** finish with studded, black lip
  • 0mm offset and 4.75" backspace
  • Cast aluminum construction
Hyper-Aggressive Look Influenced by Ken Block
The fifteen52 Turbomac HD Wheel is one of the most unique and aggressive light truck wheels on the market, and makes for an awesome upgrade to your 2004-2021 F150 or Raptor. Designed with input from the legendary Ken Block and tested out on Ken's own Ford Raptor, the fifteen52 Turbomac HD is strong enough to survive even the most extreme applications while making your F150 or Raptor look like one of the toughest trucks on the road. The Turbomac HD features a unique dual-spoke pattern design that's combined with an aggressively-sculpted lip with stainless steel studs that set it apart from basically every other F150 wheel on the market today.Cast Aluminum Construction with Hubcentric Design and Aggressive Offset
Each Turbomac HD is built extremely tough and will survive whatever application you have in mind for your F150 or Raptor build. The Turbomac HD is made out of monoblock cast aluminum that's then expertly machined into the wheel's final look. This version of the Turbomac comes in fifteen52's Block Bronze finish with a black simulated beadlock ring that is sure to turn heads both on and off-road. The wheel features a standard 6x135mm bolt pattern and a stock 87.1mm hub bore, which makes it a fully hubcentric wheel. The 17x.8.5" Turbomac HD features a 0mm offset and 4.75" of backspace which pushes it farther than stock to help you clear wide wheels and add an aggressive stance to your F150.
Wheel Specs:
  • Size: 17x8.5"
  • Offset: 0mm
  • Backspace: 4.75"
  • Hub Bore: 87.1mm
Fitment: 2004-2021 Ford F150
F150ROD
U.S. Navy Retired
Love these wheels! Can I fit them on a 2WD without a lift?
Stage3Motorsports
Stage3Motorsports
Arizona
As long as you arent trying to run a larger tire it should be fine.
Dnpbakon
Kevin
Jacksonville,Fl
2021 XLT F150 leadfoot
Retired Military
Hate to bring this back from the dead but is this still available? Ready to buy asap.
Stage3Motorsports
Stage3Motorsports
Arizona
No need to appologize these post are here to be brought back alive whenever needed. We currently have black and carbon grey in stock. PM me with what you are looking for.
