Extra leaf spring for max tow?
BoilerTimmay
Tim
Indiana
2011 SCREW 3.5L
I was reading on Facebool that the 2021 went to a two leaf spring config, with a thicker primary spring. However some mentioned that max tow had three springs. Can anyone confirm on both configs?
currybob
Bob
Alexandria Alabama
2021KRF150 PB; 2020 LexusRX350; 2021 Mazda Miata
Retired Physicist from federal government; Army Veteran
This is a Platinum on first photo with max tow.
Ford F-150 Lightning Extra leaf spring for max tow? 1609686676668
Ford F-150 Lightning Extra leaf spring for max tow? 1609686722147
billybob
2012 Focus SEL
I tried to find a source but the max tow options use a conventional steel 3 leaf design while the non-max tow use a new composite 2 leaf design.
daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
Ford F-150 Lightning Extra leaf spring for max tow? 1609976553986
I have been trying to match up white door stickers (axle ratings) with the maxtow and regular tow packages to determine what gets you the upgraded rear axle.
4800# is HDPP package only. The 4150# rear axle is all powerboosts (reg or max tow it seems) and I have seen 2 versions of EB maxtow: One with 3800# rear and one with 4150# rear. The 4150# data point I took a picture of myself. The other data point could have been bad information but I have not seen more help in my GAWR thread.
https://www.f150gen14.com/forum/threads/gawr-axle-stickers-for-regular-max-tow-and-eb-pb.872/
If we could get more folx to post white door stickers we would know for sure what the variables are to get that 4150# axle in non powerboosts.
You can see that going from 3800->4150 gets you the 3rd leaf, so it is an important difference to note.
Camptruck
Linus
Canada - Ontario
2017 Volt, 2021 F-150 XLT Velocity Blue
Project Manager
In the Weight Ratings section of the specs document, it specifies the axle rating of the various cab and wheel base options. I believe taking the axle rating from that table and applying it to Spring Spec table you referenced will show what springs will be put on the truck. Though I do note they don't use the same terminology (Max GVAR vs Comb. Rating @ Ground (lbs)).
Power Kid
Corn fields
F150
Farmer
Ancient history but max tow had 4 in MY2009 until I beleive job 2 MY2010. Then back to 3.
Polo08816
2014 BMW 335i
Does anyone have the part numbers for these rear leaf springs? In case someone wants to retrofit their non HDPP F150 with the leaf spring packs with a higher spring rate. I know this won't increase your actual tow or payload rating legally, however, it should improve handling when the rear axle is loaded.
Knickell
Kyle
Mazda Protege, Ford F-150
Good to know about that extra leaf. Anyone have an opinion on in it will improve or hurt the ride quality?
C_Low
Cody
2021 F-150 Lariat Sport
I’d be curious also. I ordered mine with the max tow package.
Pedaldude
Arizona
I will know in a few weeks, my guess is that it will not be as comfy unloaded and especially uncomfy in the regular cab.
I don’t see why Ford offers the same suspension, from the base XL all the way to the Platinum and Limited. Something like air suspension from Expedition/Navigator would make more sense on a nearly six figure truck. It really shows why it has become Ford’s cash cow.
If the ride is really rough, since most of my miles will be unloaded, I may swap out the springs for the lower spring rate ones and install airbags for the few instances where the higher spring rate is needed.
Then again, I might also get a Tommy Gate hydraulic liftgate, so with 500lbs on the rear bumper, who knows, I might need the original spring pack and airbags. It all depends, more than likely, the truck will remain stock while under warranty.
currybob
Bob
Alexandria Alabama
Mine is a max tow and has the 3rd leaf spring. No rough ride here, best riding F150 I've ever driven.
Ford F-150 Lightning Extra leaf spring for max tow? 1612632929749
Knickell
Kyle
Glad to hear that. It was one of my slight concerns since I have the Max Tow package.
currybob
Bob
Alexandria Alabama
You can throw that one out, this truck rivals my wife's 2020 Lexus RX350.
