FYI - I am not sure if it was user error on my part; however, changing the APIM module to add auto heated/cooled seats removed the Auto temperature readout in the status bar on the SYNC display in my 22MY Platinum. For those unaware, 22MY does not have the LCD temperature readout for the current setting in the climate control dial as pictured in ROBB1's post which Im sure his is a 21MY. Us 22MY owners are dependent on the status bar to show the current climate control temperature for our auto temperature settings. When I reverted to the APIM As-Built, the temperature readout returned. I am sure I could play with the value to retain the temperature display and the auto heated/colled seats, but I don't think I will use this feature much anyway. Thanks to ROBB1 for all of his help on this feature and others and of course Livnitup for paving the way for all of us.You are the man!
Based on this info I was able to enable Auto heated and cooled seats.
Seats automatically heat or cool based on internal truck temp and selected temp. You will also see a APIM display of your temp selection and whether you are in Auto mode or not. Manual control is retained via the buttons. I just implemented this tonight and everything seems works as expected in auto, but I haven't done any long term testing, so mileage may vary. You will need heat / cooled seats and auto climate for this to work.
My truck is a 2021 402A Tremor which is equivalent to a 502A Lariat. Other trims should verify your original as-build against the spread sheet for possible differences.
HVAC
733-01-08 xxxx x1xx xx (Original As-built 0)
APIM
7D0-02-02 1xxx xxxx xx (Original As-built 0)
I think the only requirement is having Sync 21146 Rev 145 (at least for me with early 2021 truck). I have not had any glitches or loss of function with the 3 module changes.Hi guys. Been watching this forum for a while and finally joined. I did some simple things like Bambi mode and double honk but I was really waiting for cameras while in motion. I haven’t checked for a while but I now see with 3 module changes use earlier build 21 guys can get it? Is there any glitches or hangups with this or is it good to go?
I’ll have to look what I have. I know it updated last night….I think the only requirement is having Sync 21146 Rev 145 (at least for me with early 2021 truck). I have not had any glitches or loss of function with the 3 module changes.
I encountered this as well, no idea thoughWhen trying to backup all modules before writing my mods, I managed to back them all up but the SOBDMC. Can't imagine I'll be making any changes to that module anyway but was curious before proceeding if anyone else has had this issue? When I run it, I get a service procedure has been interrupted fault. Thanks!
Love the "Lincoln AutoFold" tow mirrors, but I like the Puddle Lights better (so I had to switch it back...).FYI - if you set the Lincoln Autofold option, it disables the under mirror puddle lights.
Works for me, did it last week. I got OTA 2.3 a few weeks ago though. Might help if you list your Sync version if others are on the same with it working they could help.Tried doing the Forscan cameras at speed with no success. Is this supposed to work even if the truck has never received any OTA updates. Got a job 1 platinum powerboost.
Anybody able to get Lincoln AutoFold AND Puddle Lights to work at the same time??
I believe you need to be in at least PowerUp 2.3 for it to work. At least 2.x. That can be via OTA updates and/or FDRS updates. I believe if you get all the updates via FDRS, the bed camera card will work.Tried doing the Forscan cameras at speed with no success. Is this supposed to work even if the truck has never received any OTA updates. Got a job 1 platinum powerboost.
Dealer must perform an IPMA update first.Tried doing the Forscan cameras at speed with no success. Is this supposed to work even if the truck has never received any OTA updates. Got a job 1 platinum powerboost.
