Can you swap in a power seat into the Pro like in other F150s?
Lightning_Bob
FL
Reserved Lightning...
Greetings All,
In base level gas F150s you can swap the manual seat with a power seat as it shares the same fuse box and wiring harness in models with the power seats:
https://www.f150forum.com/f118/manual-seat-power-seat-swap-505814/
Does the Lightning pro share the same fuse and wiring harness as the XLT with power seats?
FordLightningMan
Upstate New York
F150
As a XLT SR owner in a cold climate, I am curious how easy (possible?) and costly it will be to add a heated seat to the vehicle. It is the one trim option sorely missing, so I'll be watching this thread closely!
sotek2345
Engineering Manager
There are lots of aftermarket options out there ranging from cheap (~$50) for something you put on your seat and plug into the 12V outlet to expensive ($hundreds-$thousands) for re-covered seats with heating (Katskin)
Lightning_Bob
FL
Good to know!
From reading the posts about seat swaps - it looks like as long as the seat gets 12v & ground it is happy....Mostly looking into power seats as it doesnt seem like there are manual seats with adjustable height?
....wonder if I could hook up a centrifugal fan for a ventilated seat swap ;-)
vbaker4444
Vic
2021 Mach E Select AWD
Following this thread closely as I wouldn't mind swapping some upgraded seats into my pro at some point.
broncoaz
Cape Cod, MA
Also following.
Mcalc55
F1504855
2022 Lightning Pro
Following although i got my pro today and must say i think the seats are alright! They lack some lumbar support though. It sort of feels like theres an air bubble behind your back and depending how you lean on the seat it fills up based on the pressure youre putting against it…definitely the poorest mans lumbar support
