Tire size with a 2” level
C_Low
Cody
2021 F-150 Lariat Sport
What’s going on y’all! I’m new near! I know everyone is probably excited about their new trucks and new builds. I just recently ordered a 2021 lariat sport 502A FX4 at my local dealer.
I’m already looking at ordering parts and having them ready for when it arrives. I’m wanting to do a 2” level with ReadyLift and add some A/T tires 33-34’s.
What do y’all think...I’m looking at the Toyo Open Country AT3’s, Ridge Grapplers, or KO2’s. The sizes I’m thinking are 295/60/20, 285/65/20, or 285/60/20. I’m not wanting any rubbing or any trimming so I’m not sure which size to go with. What do y’all recommend? I’m wanting to keep the ride quality as good as possible but adding that bad ass look at the same time.
On a side note, has anyone noticed that the new runningboards sound very loud? I currently have a 2017 Ford F150 platinum with runningboards and they are not loud compared to what they sound like now.
mrtrav
Travis
SW WA
2021 F150 Lariat Sport
I’m going to eventually go with Ridge Grappler 285’s. Undecided if I am going to do that day 1 or wait for the OEM’s to run their course. Other upgrades I could use that $1k for in the near term.
F150 4X4
Larry
Des Moines
2021 F150
Will just a 2 inch level make a Fx4 level ? I really don't want to go over 2 inch.
C_Low
C_Low
Cody
It’s not going to be perfectly level. I think there will still be a small rake, but I don’t wanna go over 2” either. 2” will be very close to level, and plenty IMO. The higher you go the more the ride quality will suffer.
C_Low
C_Low
Cody
Yea I don’t want any rubbing, especially on the UCA at full lock. Iv had that issue before and don’t wanna do that again. But I had true 35’s on a 2” level on my 17 F150.
satexas
Russ
San Antonio
F150 PB 2021 L502a
You want 275/65/20. That's your realistic max.
Elkhunter
Monument Co
2021 F-150 Lariat
I did the 2" and it sits just a bit low in the front, the 2.25 would probably be perfectly level. On a side note the ride quality did not suffer one bit with my set up.
C_Low
C_Low
Cody
Good to know. Thank you. Did you put on a bigger tire?
Elkhunter
Monument Co
2021 F-150 Lariat
working on it. 295/60/20 is what I'm looking at going with.
05RubiconLJ
Matt
Arkansas
'05 Rubicon LJ, '21 F-150 Platinum Powerboost
I have started to lean towards the 275/65-20. Just slightly taller than the 295, but stock width. More importantly, there are more choices of tire brands and they run $80-$100 per tire cheaper than their 295/60-20 counterpart.
jtquint
Colorado
2021 F150 Platinum Powerboost - Smoked Quartz
That is the size I went with. I still need to level when the parts are in stock. Everything is fine without rubbing for now unless I full turn and go in reverse. I have a powerboost and pretty sure my mileage took a hit (as expected)
C_Low
C_Low
Cody
Iv been thinking about that size or 285/65/20.
Not my truck. But this truck is leveled with the 285/65/20 Nitto RG.
Ford F-150 Lightning Tire size with a 2” level D19E901D-908C-4AB8-AEAD-7AC12BC3FEDF
Ford F-150 Lightning Tire size with a 2” level 9BE489E4-AC9E-4322-AF5E-515069BAEC4E
Krock7360
Ken
Alabama
2021 Ford F-150 Platinum
295/60/20
C_Low
C_Low
Cody
Where do you rub at? UCA or like a plastic piece on the body?
