Seriously… why did they make that frunk beep?
xycarp
SE Michigan
2021 Bronco Sasquatch, Lighting Lariat ER on order
From the Urban Dictionary…
Ford F-150 Lightning Seriously… why did they make that frunk beep? 5393F8C3-A241-453D-ACC7-213CA860F42D
Dcdds
2021 bronco 2003 expedition
Is Forscan not an option to solve this?
While the beep is annoying, there is a second big part of Ford's annoying antics with the Frunk - Why in the world do they shut down the truck when opening the Frunk?
If you remote start the truck and then open the frunk before getting in - the AC/truck shuts down. WTH? There is nothing about the two that are related.
If they think it is something about the huge fan running loudly for the AC heat exchanger that isn't even accessible from under the frunk, that is under the heat exchangers.
WTH Ford.
LightningShow
MA
'22 Lariat ER
Product Development
WTH Ford.
When lawyers make decisions...
Akbrian
Alaska
F150 Lightning 2022
The front hatch control module is in there if you want to mess with unlatch timing reset. Don’t see anything about motor speed or noise. My guess is the beeper is part of a circuit that will register as a circuit short to battery or open and disable the electric open close system and throw a dtc.
MickeyAO
Mickey
San Antonio Tx
Ford F-150 Lightning Seriously… why did they make that frunk beep? 20221114_151447
I only had 15 minutes to look, but I have narrowed it down to this area (front passenger side). It is so much loader when the frunk is removed, so it has to be under the frunk enclosure. Pro tip for hunting it down...the escape button will cause the beeping to start, so you don't have to worry about the frunk closing on your head.
xycarp
SE Michigan
Great progress. Keep digging!
No one has access to the parts/repair manual?
MickeyAO
Mickey
San Antonio Tx
I've been searching that also...I can't find anything on it.
skyak
F250, 911, Lightning
Found this, not sure if it is Lightning related.
Ford F-150 Lightning Seriously… why did they make that frunk beep? 1668477338083
FordLightningMan
Upstate New York
F150
I think the problem with all of the beeps on the truck is they are too loud, not that they exist. I absolutely hate locking the truck, because the noise that comes out of it can wake up everyone in my neighborhood. The frunk is similar, why is it so loud? If Ford could cut the volume in half on all these beeps, it would be much appreciated.
skyak
No noises here when locking unless I press the button twice. I do look back for the mirror fold though.
I used to lock by hitting the button on the door and it was done, but I read locking like that doesn't set the intrusion / motion alarm. Activated only from the remote or PAAK if I recall right.
sotek2345
Engineering Manager
Interesting, I always lock on the door. I wish it had lock on walk away like the Mach-e!
