Linex prep questions answered by local installer
azDcab21
Ken
Az
2021 PowerBoost/FX4
I emailed my local Linex shop with questions about the prep steps they use when applying Linex. Thought it might be useful to others. I imagine that all Linex installers should follow a similar procedure.
(1) We remove the OB power box and spray behind it.
(2) We remove tie downs and bed bolts at customer request.
(3) We tape off the led Lights and remove/reinstall button.
(4) We leave rubber drains plugs in and spray over them.
(5) We will remove tailgate and spray it upon request. It is only a 2 inch border we will spray, Behind that cover is just an open tailgate.
(6) We use 80- grit sand paper to prep the bed sanding just the clear coat only and cleaning the extremely well before spray. we only install the bed of the truck in our booth dropping a plastic wall to separate the cab from the bed.
Icbmredrat
Wade
Toronto
F-150 XLT 4x4 Supercrew
Thanks for the info.
I’m having a hard time getting a ballpark price for a standard coating of Line X... do you happen to know how much?
Thanks
Broccoli Rob
Alex
2014 Ford Fusion Titanium Hybrid
Thanks
I was quoted 650 for the premium coating, I think it was 450 for the standard? But that's a 50ish dollar discount applied in each case
kosekjm
North Carolina
2021 F150 XLT 302A 3.5 Powerboost FX4 5.5' Bed
Software Engineer
I had the premium done in Raleigh, NC mid February and that ran at about $670 (With Tax).
All parts and pieces were removed and reinstalled (Except possibly the tailgate as I still have the factory paint on the bottom side of the tailgate). All lights, buttons, tie downs are functional. No overspray that i could see anywhere on the truck.
All in all much nicer then the drop in liner I had on my 2012.
Ford F-150 Lightning Linex prep questions answered by local installer 20210216_154533
Ford F-150 Lightning Linex prep questions answered by local installer 20210216_154523
Ford F-150 Lightning Linex prep questions answered by local installer 20210216_154516
Ford F-150 Lightning Linex prep questions answered by local installer 20210216_154548
Cal_jammer
Scott
St. Louis
2021 F-150 XLT, 2013 Triumph Bonneville
Thanks
Mine was $400 for the standard, if you're a AAA member they knocked off $50 I believe
azDcab21
azDcab21
Ken
Az
2021 PowerBoost/FX4
This was the standard pricing I was given here in AZ
Our bedliner pricing for your vehicle with our
Standard Line-x is $550-$600+ tax.
LINE-X PREMIUM –. $650-$700+ tax.
LINE-X XTRA – . $900-$950+ tax.
LINE-X PLATINUM– $775+ tax.
Icbmredrat
Wade
Toronto
Nice. Thanks. They finally returned my call and here in Toronto it’s going for $575 + tax for the standard spray. I just hope they have experience with the 2021.
Also a side note, I keep hearing people talking about scuffs / scratches with Line X. Are they taking about the product scratching the cargo?
Thanks
Agashi25
Arban
Chicago
2015 Mustang GT PP CO
this is in line with IL from what I got back.
Knickell
Kyle
Mazda Protege, Ford F-150
Thank you. I think I’ll want the border of the tailgate sprayed as well.
blueovalguy
Dan
NY
2021 Lariat Powerboost
I just called the local one by me and luckily they are the krown people too so it’s only 450 for standard. He said basically no one does the premium one.... would like anyone that has used both to comment.
He also said they just tape off around pro power and tailgate surface. So not sure if these guys are just lazy compared to original post? Should I be demanding they remove and spray behind? Should I remove stuff myself so they don’t strip anything?
UNCGrad
Melissa
Clearwater, FL
2021 Ford F150 AMB Platinum 3.5 Ecoboost 6.5 bed
So you have the strip below the tailgate that was left bare correct? I thought it was strange so I asked my installer and he said for the 21 tailgate to work properly, it has to be bare.
kosekjm
North Carolina
Software Engineer
Ford F-150 Lightning Linex prep questions answered by local installer tailgate
Right below the plastic bit of the tailgate is covered. The lower edge is not covered (What would be the underside of the tailgate when closed.)
I can try and grab a better pic this weekend for you if need be
Icbmredrat
Wade
Toronto
Here in the GTA at my local Line X dealer, I was charged $570 + HST.
Everything was sprayed including the bed bolts and appears that major parts were removed. When I asked how come bolts were sprayed, the gentlemen said protection and can be easily accessed with a knife. Took about 2 hours and the tailgate was removed.
